Didn't work with dvdshrink, or dvddecrypter. dvdfab made a "movie only" that works but full disk mode doesn't work. Internet explorer shows 12 VTS's on original DVD, each with 9 VOB's totalling appr. 79 Gb's.
I've never seen, or heard about such a copy protection scheme.
Any suggestions?
Face the facts, find a solution, stick to it!
It's very common to have multiple directory entries refer to the same data to make the contents look bigger.
It's not copy protection. You may find that there are nine different credit sequences, each in a different language. Depending on how the disc has been authored to branch to these, it could well appear to be 9 titles, all the same length. Star Wars did this, as do many other others.
If you want to do a full disc, copy the results to an ISO, instead of folder, then burn with with Imburn. If you go down the ISO path then you don't have to worry about the titles and structure.Read my blog here.
I used dvdremakepro to change commands in IFO's to go from "play first" directly to VTS_1 menu. Works now.
But thanx for the answers.Face the facts, find a solution, stick to it!
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
best software to make "fair use" backups of DVDs to DVD +/-R?
By gastrof in forum DVD RippingReplies: 4Last Post: 14th Jun 2011, 14:27 -
Does the psn outage make you hesistant about a "cloud" future?
By yoda313 in forum Off topicReplies: 11Last Post: 1st Jun 2011, 19:58 -
someone suggest screen capture software to make a "movie"
By graysky in forum Newbie / General discussionsReplies: 2Last Post: 13th Jan 2008, 05:08 -
Make menu for "VIDEO_TS" folder (files inside it)...
By Chana1 in forum Authoring (DVD)Replies: 18Last Post: 24th Jul 2007, 08:29
