I am a little lost as to how subtitles are handled in AVIs. I have used AVIAddXSubs to merge the subtitles into the AVI. This results in switchable subs in my standalone divx player. When I join the two such AVIs using VirtualDub in direct video stream copy mode the subtitles are not available in my stand alone player, WMP, MPC or Nero Show Time.
A little further checking reveals that none of the PC software players will show subtitles for the separate AVIs made by AVIAddXSubs but they are switchable on the Oppo DV-970HD. Very pleased that the Oppo has USB input, a flash drive has saved many CD/DVDs.
AHha! MediaInfo shows DivX subtitles in the AVIAddXSubs built files but they are absent from the VirtualDub built file.
What am I doing wrong or is there a better way. The subtitles don't have to be switchable but it would be nice.
Any help appreciated, John.
I would use SubtitleWorkshop to append and adjust the timing of the two SRT files, append the AVI files without subs, then mux the appended subs into the AVI.
Actually I would just leave the video as two AVI files with separate SRT files but you seem averse to that. -
My player will not (afaik) pick up the SRT files, I did try that, therein lies the problem. It also turns out that the audio sample rates are different in the AVIs, VitualDub does not object but VitualDubMod does (?).
Most players support external SRT subs. Try using short 8.3 filenames, all caps, only alphanumeric characters. Like:Originally Posted by hibbs
VIDEO.AVI
VIDEO.SRT
I suspect there will be playback problems even if VirtualDub does allow different audio sample rates. I would convert one to make it identical to the other.Originally Posted by hibbs -
Thanks for your help. After a few trials I've found that XviD4PSP hard merges sub titles if the SRT has the same name as the AVI and I can also shrink the AVI. The AVIs were then joined with VirtualDub. Merging sutitles before appending the AVIs avoids sync problems in the second AVI.
video (xvid, avi,mkv...) AND sutbtitles (SRT) splitter
By kkm in forum Newbie / General discussionsReplies: 0Last Post: 22nd Mar 2010, 17:58 -
Embedding .SRT to .AVi (divX/XVid) for Xbox 360
By Alereon in forum MacReplies: 7Last Post: 14th Oct 2009, 11:00 -
MKV to AVI (XVID) subtitles
By theninger in forum SubtitleReplies: 12Last Post: 25th Jul 2008, 07:41 -
Error in Vdubmod when combining srt and avi
By majax79 in forum SubtitleReplies: 4Last Post: 19th Apr 2008, 04:33 -
2 Xvid avi and 2 subtitles
By ianskiee in forum Video ConversionReplies: 18Last Post: 1st Jul 2007, 12:34
