Collective brain trust, I am new to this so please be gentile.
How do I create my own custom FreeFrame plugin?
I know that FreeFrame is simply a framework and not an app. And that FreeFrame plugins can be used in a slew of host apps / NLE’s, but my question is this…
It seems that all of these host apps will save a clip as an AVI and that’s all fine and good, but what if you want to make your own FreeFrame plugin using a string of multiple readymade plugins or simply an effect you’ve created on your own that you wish to replicate?
My end goal is to create my own custom FreeFrame plugin that I can then use in another app that uses AviSynth. I know that my other app (DVDslideshowGUI) supports AviSynth FreeFrame plugins. It appears that all of the existing FreeFrame plugins used in AviSynth are DLL’s.
At this point I’ve not committed to a specific FreeFrame host app/NLE yet so if one allows you to generate your own plugin/DLL I’d like to know.
Thanks in advance for your thoughts and help.
Results 1 to 1 of 1
"A picture is worth a thousand words--But it uses up a thousand times the memory."
~ Unknown
Can I create my own custom Button in TMPGEnc Authoring Workshop 4?
By JackyWang in forum Authoring (DVD)Replies: 4Last Post: 31st Aug 2016, 22:14 -
How do I create custom DVD menus?
By aple in forum Newbie / General discussionsReplies: 6Last Post: 21st Jul 2011, 20:25 -
Is It Possible To Create A Custom Color From A Picture, For Text In Paint?
By V Bot in forum ComputerReplies: 10Last Post: 1st May 2011, 22:00 -
How create a custom Menu Backround when using convertxtodvd
By tealmarlin in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2009, 14:49 -
Best Authoring Program to create full custom menu
By quik_123 in forum Authoring (DVD)Replies: 12Last Post: 11th Oct 2008, 00:46
