hi
Every program i tried so far, either converts to 2 channel stereo or messes the sound channels order...
Any ideas?
thanks
Results 1 to 12 of 12
I dont have Nero 7 wave editor... Behappy saves in stereo only.....
I'll mux the sound with a random video to create a mkv and feed it to hdconverttox or megui and see what happens
It's possible you didn't set behappy up correctly; try using bassaudiosource() for aac input (depending on where you got behappy, you may need to download components and dll's separately)Originally Posted by nasdravi
Make sure your directshow chain isn't downmixing to stereo (e.g. mixer in ffdshow isn't checked off)
If you are using MeGUI, you don't need to mux to video, just use the audio -
I added the bassaudio dlls to behappy, still saves in stereo (ffdshow mixer is checked)
I dunno what f2k is... i wish belight could open aac files...
Anyways, i made a mkv and fed it to ripbot264 and convertxtodvd, got no errors....they still encode..... i'll let u know...
Thanks for the replies
ok, convertxxtodvd worked fine, after it finished encoding i ripped the audio from the vobs with smartripper and joined the pieces with mkvmerge. Channels are in correct order
poisondeathray: yes i checked bassaudio (not directshow) in behappy. Also Ffdshow is not the problem, it is checked to 6 ch. and also ffmpeg did gave me 6 channels when i tried before, the problem was that aac and ac3 have diferent channel positions/tables ( 1 is center for aac but left for ac3) so it was messed up...
Thanks for your help
Sorry, foobar2000..I dunno what f2k is
" Who needs Google, my wife knows everything" -
Another way to convert AAC to AC3
1. Convert (Decode) AAC to wav using Nero AAC Codec (NeroAacDec.exe) command line version.
Alternatively NeroAAC UI can be used if you don't want to use command line.
2. Convert wav to ac3 using Eac3to.
Alternatively EAC3to conversion utility if you like GUI.Last edited by newyear1967; 15th Feb 2010 at 22:41.
Batch Convert 6 channel AAC to AC3?
By massarosareloud in forum Video ConversionReplies: 11Last Post: 22nd Oct 2011, 14:41 -
Convert AAC 5.1 to AC3 5.1
By ikarishinji41 in forum AudioReplies: 3Last Post: 8th Feb 2011, 01:21 -
Cannot Convert 6 Channel AAC to 2 Channel AAC - Help?
By Rez. in forum AudioReplies: 2Last Post: 3rd Dec 2009, 19:47 -
AAC to AC3 Wrong Channel Order
By midders in forum Video ConversionReplies: 12Last Post: 27th Nov 2009, 09:45 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23
