Hello All,
I have read the post by Bladrick "How to add permanent subtitle to a video with virtualdubmod" at https://forum.videohelp.com/topic272736.html and I must say that it is straight and to the point.
My issue is this. I authored my own DVDs earlier using Ulead DVD Workshop 2 and added subtitles. What I would like to do is to take the subtitles from VOB stream and add them permanently to the video as mentioned above.
Baldrick mentions that:
<<<In Virtualdubmod open your video. (If a message popups that VBR audio stream detected just select NO)
Add the TextSub filter under Video->Filters.
Open the srt, sub(text), smi, ssa subtitle.
(If you have an idx/sub/ifo subtitle add the VobSub filter intead.)>>>
My question is, how do I get an idx/sub/ifo subtitle out of my VOB files and then use that stream to add permanently to my MPEG2/VOB?
Thanks,
Wasim.
Thank you, I will try that. I have another question about joining subtitles. I will post it under a separate heading.
embedding subtitles help require
By atomicmak in forum Video ConversionReplies: 6Last Post: 31st Oct 2011, 12:39 -
Embedding Subtitles Only for particular Frames
By zammil in forum SubtitleReplies: 1Last Post: 4th Oct 2010, 12:07 -
By zammil in forum Newbie / General discussionsReplies: 1Last Post: 4th Oct 2010, 12:06 -
Embedding subtitles into video
By jane.mayers1 in forum EditingReplies: 1Last Post: 9th Dec 2007, 13:34
