I'm getting this message in VirtualDub sometimes:
'Video codec "Panasonic DV CODEC" is claiming to be able to decompress formats that it does not actually support. This can cause the Windows video codec system to malfunction and may cause applications to crash. Please remove the errant codec or replace it with an updated version from the original vendor.'
But how exactly do I remove it please, as it doesn't appear in Add/Remove Programs?
I've downloaded a new file, Panasonic_DV_codec_v2.64.exe. I could just try installing it anyway, but I'd be happier to uninstall the misbehaving one first.
Also, is there a definitive test to see that this codec is working properly please? A link to download a suitable file perhaps?
Terry, East Grinstead, UK
That's an old VFW DV codec, Cedocida is better.How to uninstall the Panasonic DV Codec
Go to the Control Panel, go to Sound and Audio Devices, go to Hardware, scroll down to Video Codecs, click Properties and select the pdvcodec.dll and click Remove."Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
Thanks Safesurfer. Moments ago found an old thread with same advice and have duly installed it. Hopefully thius by-passes the question of how to uninstall the Panasonic thing, as Cedocida should replace it I gather. But I'm curious to know how I would do that anyway?
Terry, East Grinstead, UK -
No, it won't replace it, the Panasonic will still be there. The Merit of a codec determines whether it is the preferred codec or not. I would go ahead and remove the Panasonic one.
open command prompt, type:Originally Posted by terrypin
hit enterCode:regsvr32 /u pdvcodec.dll
you may need to add path to the dll in some cases, then you'd type (for example)
regsrv32 /u C:\Windows\system32\pdvcodec.dll
or
regsrv32 /u "D:\Program Files\Panasonic Old Crap Files\pdvcodec.dll"
I guess you've got it by now
Panasonic DV codec - removal? -II-
By ledishis in forum TestReplies: 3Last Post: 10th Dec 2011, 07:44 -
Watermark removal
By Shrimpy72 in forum ffmpegX general discussionReplies: 3Last Post: 14th Jan 2011, 11:31 -
WMP CP removal
By kookie2000 in forum AudioReplies: 2Last Post: 14th Jan 2008, 16:41 -
camera flash removal
By loa909 in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2007, 09:03 -
RCE protection removal..............
By efiste2 in forum DVD RippingReplies: 12Last Post: 21st Jul 2007, 12:42
