I have just installed a new sound card and loaded the drivers with the CD .... NO sound.
Sound Card details:
C-Media 8738 PCI sound card.
Fully compatible with your Surround Sound 5.1 channel computer speaker system
This PCI card uses the C-Media CMI8738/PCI-6-CH-LC chipset
Full duplex 64-bit PCI bus master
Integrated SRS 3D sound technology
Compatible with sound blaster, sound blaster pro and Windows sound system
Advanced MPC-3 compliant input and output mixer
Enhanced stereo full duplex operation
Dual Type-F DMA support
Delta-Sigma data converters
Programmable power management
Hardware master volume control
Center/bass-out
Microphone-in
Line-in
Line-out (Front Speakers)
Rear-out (Rear Speakers)
15 pin standard game/midi port
PCI interface
System requirement: Windows 98/ME/2000/XP
P4 2g socket 478 CPU
Acer M/B chipset sis651
512Mb of DDR PC3200
10g Seagate HDD
Antec 350w PSU
ASUS CD ROM
XP Pro SP3
This computer has no software loaded outside of the bare essentials for the net, I use another PC for work.
Results 1 to 9 of 9
Check your preferred audio device in control panel, check your speaker setup and connection, check the volume panel with all settings, test with headphones. Also confirm device installation in Device manager.
are you looking for analog or digital output?Originally Posted by blinky88
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
Does your mobo have onboard sound? If it does, you may need to disable it in the BIOS for the add on card to work.
Re-loaded the OS, now operating as it should.
Thanks to all for taking time out to help, appreciated. -
Are you getting Dolby Digital w/ Showtime?Originally Posted by blinky88
ocgw
Please describe EXACTLY the procedure you were using to test sound card function.
Playing an AC3 or similar file with no native support built-in to the OS? Or did you try the WAV files built-in to the system, which do not require any additional software for playback? -
Problem solved by installing new OS .... Re installing the OS also loaded the AGP which also was causing problems.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
[VHS conversion] Sound Card, Video Card?
By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02 -
What are the downsides to having both onboard sound and Sound Card enabled?
By c627627 in forum Capturing and VCRReplies: 0Last Post: 21st May 2010, 15:44 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
on board sound card
By m baqar in forum Authoring (VCD/SVCD)Replies: 2Last Post: 26th Mar 2008, 23:26
