  1. Member wulf109's Avatar
    Jul 2002
    MMJB 7.5 wouldn't open,so I un-installed. But I couldn't re-install it. I tried several different versions,no luck. the installer just would not load. Only way I could solve the problem was to install XP on another HD,I have 4 HD's. That worked,so I'll run MMJB from the other HD. Anyone have any idea why I couldn't re-install on my C drive.
  2. gave up on mmjb long ago. you might give mediamonkey a try. similar once you set up the gui the way you want, but without the registration hassles/online checks of mmjb.
  3. Member wulf109's Avatar
    Jul 2002
    Does Mediamonkey print CD jewel case inserts? MMJB plays,tags,burns,and print inserts. Do any other "jukeboxes" do all of those?
  4. it will export track lists and burn cds, but no printing any labels in mediamonkey. there are many cd label printing standalone apps that will though. makings cds from mp3's is not a thing i've ever done anyway. audio quality sucks big time, and pressed cd's are bad enough to start with....
    i was a mmjb user since v5.0 until they cut off registered user updates and then yahole bought it. i really don't miss it at all with mm. especially all the "background" crud mmjb loads at windows startup. it was not a very stable program either.
    Nov 2002
    Did you update to IE7?
    I googled your problem and everyone in two different threads said their problem started when they updated to IE7. After reverting back to IE6, they could install and start MMJB 7.5.
    EDIT: Here is a link that explains how to run MMJB 7.5 on a machine with I7...
    http://forums.techguy.org/multimedia/773806-success-musicmatch-jukebox-7-5-a.html
