Every time I try to use light scribe it does it on the wrong side of the disk and ruines it so the disk to longer works! If I flip the disk over so it does it on the correct side it says no disk found? any suggestions?
spam
Closed Thread
Welcome to the forums.
Has Lightscribe ever worked correctly for you? If it worked OK in the past, do note that the Lightscribe capability on burners can stop working. There's nothing you can do but get a new drive. I had that happen to me when I used Lightscribe in the past.
The only Lightscribe discs I would buy are Verbatim. I don't trust any other brand. Also, not to imply that you don't know what you are doing, but what you should do is burn the data to the disc first with the data side down as normal and then after you are finished burning the data, flip the disc over with the Lightscribe side down and burn your image. It should not damage the data side if you do it in that order.
Scribe Transcription Software
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 27th Sep 2011, 17:02 -
Adjusting amount of light
By ProducerHarley in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 28th Jan 2009, 18:07 -
Laser Etching DVDR That are NOT Light Scribe Discs.
By Scooter_NJ in forum Authoring (DVD)Replies: 4Last Post: 17th Nov 2008, 18:11 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
Low-light shooting
By azinkin in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 17th Mar 2008, 15:12
