The source was a DVD made from a MiniDV tape. The converter/capture unit was VirtualDubMPEG2. I had captured/converted the video using a 2000kbps bitrate on DivX 6.7 codec, and the video is 3 minutes and 57 seconds long.
It looked fine (by far the best render) when I played it back. When I imported the file in Premier, however, the dialog just said "Importing files" and stayed forever at zero, not getting ahead. I looked for solutions, but couldn't use any of them. I looked for other instances of this problem and didn't find any. I want to use a file of similar size and top quality, ripped from the DVD, while working on Premiere. What can I do?
Premiere doesn't like high-compression files for import. It is a pro app, and expects uncompressed or lightly-compressed video input.
No, it's an inflexible piece of crap like all Adobe products.Originally Posted by lordsmurf
Not sure why you would want to convert it before use in Premiere Pro instead of using the extracted MPEG2, is disk space really that much of a problem? If so, I would investigate frameserving from the DVD, that way you avoid any intermediate files, see the link https://forum.videohelp.com/topic261416.html for one method.
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
If you capture your minidv tape to DV AVI, you get the exact bits and bytes that were recorded onto the tape without any further encoding or compression. Premiere LOVES DV-AVI and was designed to work best with that format. However, Premiere's designers never intended it to be a divx/xvid editor. The divx/xvid formats are highly compressed PLAYBACK formats not designed for editing.
Edit first in DV-AVI, and then convert your final edited product to Divx. You have everything backwards in your workflow. -
Sorry you feel that way, Jagabo. I made this with After Effects, Premier Pro and Soudbooth. Although it's not production quality, I had fun with it and found them easy to work with and worth every penny.Originally Posted by jagabo
Click here to view -
Older versions of Premiere were really inflexible. CS4 works with many more kinds of input formats and compatiblity has improved
Another option is the avs import plugin for Premiere, which is another way of frameserving (newer and more stable than using vfapi as outlined in the above link)
Windows Movie Maker capture import to Premiere Pro
By burrenyoga in forum Capturing and VCRReplies: 5Last Post: 24th Aug 2010, 10:36 -
Premiere Pro CS3 and TMPGEnc - Can import AVI but video does not show up...
By chadsxe in forum Newbie / General discussionsReplies: 4Last Post: 15th Feb 2008, 14:05 -
Cant import AVI files into Adobe Premiere Pro 1.5 (again)
By Undead Sega in forum EditingReplies: 1Last Post: 13th Oct 2007, 21:35 -
Premiere Pro 1.5 Won't Import Any AVI? Zoiks!
By glowing_zebra in forum DVD RippingReplies: 1Last Post: 7th Jul 2007, 05:28 -
Premiere Pro to xvid or divx AVI
By foochuck in forum Newbie / General discussionsReplies: 0Last Post: 1st Jul 2007, 20:48
