Hi,
I have an xbox 360 connected to my monitor with a VGA cable through the cooler king which has composite and av input My pc which accepts VGA is right next to the xbox and i was wondering what the cheapest and HD or SD solution would be for me. If there is no solution I have the option to buy a tv which accepts vga, composite and av input if that is better with a cheaper solution then i would prefer it.
Or i was thinking is it possible to split a vga connection into av and then record using easycap at 60hz
Thanks![]()
are you wondering why this post has gone 5 days without a reply?
it is because you have neglected to ask any questions, and we are not sure what you are trying to accomplish
are you trying to record game play footage?
do you want to play and record at the same time?
do you want to use your computer monitor to play but would like to know how to get the best quality?
try formating your post something like this:
cheershi there,
i would like to ...
i have this computer...
with this capture card...(make and model of your CC)
and i am using this device attached to my 360...(make and model of the equipment in the pic so we can see if it is able to display video from the different outputs at the same time)
i would like to know how to best use the equipment i have to achieve what i would like to do
Help capturing xbox 360 video when xbox is connected to monitor with vga
By laldabomb8 in forum Capturing and VCRReplies: 0Last Post: 23rd Jul 2010, 03:05 -
how do you record xbox 360 gameplay while using microsofts xbox 360 vga ?
By rushinplaya in forum Capturing and VCRReplies: 18Last Post: 3rd Apr 2010, 07:19 -
Capturing Xbox 360 using VGA
By bigboss50 in forum Capturing and VCRReplies: 14Last Post: 27th Mar 2010, 14:51 -
Xbox 360 to pc without a lan connection??
By yoda313 in forum ComputerReplies: 19Last Post: 6th May 2008, 10:59 -
Record XBOX 360 to Laptop using a VGA cord
By Renzeko in forum Capturing and VCRReplies: 1Last Post: 18th Jul 2007, 22:35
