    Mar 2009
    What do I do so all EXCEL, POWERPOINT and WORD is in ARIEL? (in Microsoft Office 2007)
    All these programs are factory set up to default to CALIBRI. I don't think CALIBRI is pretty so I want these programs to automatically type in ARIEL.
    orfa jackson
    USA
    Word:
    1 Under the Home tab, click the Styles group button to open the Styles window.
    2 Click the Manage Styles button, which is third from the left at the bottom of the Styles window.
    3 Select the Set Defaults tab.
    4 Scroll to and select Arial under Font.
    5 Under Size, click 12.
    6 Select the Only In This Document check box.
    7 Click OK.
    Now you no longer have to reformat your Word 2007 document to work in Arial 12.
    If you are working on your own machine, you can set the default font for all new documents by clicking the New Documents Based On This Template check box in step 6.
    Excel:
    1 Click the Office button and then click Excel Options. The Excel Options dialog box appears.
    2 In the Popular category, click the Use this font drop-down arrow. A list of available fonts appears.
    2 Select the desired font from the list. You may want to preview fonts in the worksheet before you choose a new default font.
    3 Click the Font size drop-down arrow and select a font size from the list.
    The font sizes range from 8 to 72 points. If you don’t see font size you want, you can type a different size, such as 9.5 or 15, in the Font size box.
    4 Click OK to close the dialog box.
    Note You must restart Microsoft Office Excel to begin using the new default font and font size. The new default font and font size are used only in new workbooks that you create after you restart Excel. Existing workbooks are not affected.
    PowerPoint:
    http://presentationsoft.about.com/od/powerpoint2007tips/f/07defaultfont.htm
    And since this is a computer question, moving you to the Computer Forum.
    Mar 2009
    Thank you.
    And for PUBLISHER?
    little orfa
    Mar 2009
    Thank you, you are kind.
    little orfa
