Hi,
We have WMV Files but we need files with YUY2 raw video format.
Does normal WMV files has RGB raw video format ?
Regards
Deepak
Have a read of http://www.microsoft.com/windows/windowsmedia/howto/articles/AdvancedEncoding.aspx
If you are encoding WMVs, WME has an option in the Processing tab of the Session Properties to set the pixel format.Capturing to Optimal Pixel Formats
It is recommended that you capture to a YUY2 (4:2:2) pixel format, which enables you to avoid pixel format conversions during encoding. The Windows Media Video 9 Series codec is primarily a 4:2:0 pixel format, except that if you choose to maintain the interlacing in your content (a new feature with Windows Media Encoder 9 Series), then a 4:1:1 pixel format is used. Because the YUY2 format is a superset of both 4:2:0 and 4:1:1 pixel formats, the content can be converted to either format without any data loss.
An important note is that if you capture to a 4:2:0 AVI file (for example I420, YV12, or IYUV), you will not be able to maintain the interlacing in your source video.
Older capture devices may create AVI files that do not fully conform to published specifications, resulting in upside-down video with the YUY2 pixel format. To prevent this, you can either set the driver on your capture device to use a different pixel format, or you can "flip" the image if your driver provides such a feature. Finally, there is also an option to flip the video in the encoder.
The RGB pixel formats are not recommended, because they result in extra color-space conversions, bigger files, and more data to move across the bus."Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope" -
If you want to check what is inside the raw video files, you can use 7yuv app (link from my signature).
It is a raw image file viewer, which understands many raw YUV video formats.datahammer.de - home of 7yuv the Raw Image Video Sequence Analyzer
file format for storing video files (wmv or h.264)
By the_shyguy in forum Video ConversionReplies: 24Last Post: 10th May 2010, 01:21 -
Converting raw DV format into a quicktime or MPEG format
By Maiden in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 80Last Post: 27th Apr 2009, 20:00 -
Burn authored VIDEO_TS as UDF or CDFS (or RAW) file system format?
By PCat in forum Authoring (DVD)Replies: 4Last Post: 26th Jan 2009, 16:33 -
dvd-rw discs show up as raw file format
By Bertieboo in forum MediaReplies: 3Last Post: 20th Nov 2007, 09:44 -
Raw YUY2 to YV12 format?
By allyli2007 in forum ProgrammingReplies: 8Last Post: 2nd Jun 2007, 12:43
