Newbie here ---- Need to learn how to put hi-def files to a blu-ray disc......so it will play back on any blu-ray player.
I recorded some tv programming using my hauppauge hd pvr (720p ans 1080i) and need to know how to successfully make a blu-ray video, and not just a bd-rom. The files I recorded are .ts files or m2ts. files. (I would prefer to not have to convert them.)
I have a pioneer blu-ray burner. And 1 bd-rewritable disc that I plan on using a lot since I will likely mess up a lot.
What would be the best software to use to do this? Also, what would be the best software to manually cut out the commericals of tv shows.
I will do some research for sure, but any tips, direction would be much appreciated.
Thanks.
I would try multiAVCHD!
Or maybe tmpgenc authoring works if you want to do some basic editing also.
Can you put DVD quality (and structure) video on a Blu-Ray disc?
By rayden54 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2011, 03:17 -
Can you rip a blu ray file, make edits, and put it back onto the same disc?
By FatalX in forum Blu-ray RippingReplies: 6Last Post: 24th Apr 2010, 17:49 -
Introducing Ray in Blu Rendr - Digital Media Receiver Blu-ray Disc
By rayinblu in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2010, 10:37 -
Put Blu Ray disc in regular DVD player???
By Tech Challenged in forum Newbie / General discussionsReplies: 18Last Post: 20th Feb 2009, 11:09 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
