Hello there,
I have put together numerous projects in DVDlab Pro, always with the success possible in V. 1.6 (I prefer the rendering of subs, they look far better.)
This time - regardless of settings (AFAIK) - the subs come out all black...
I did the following (as always):
- rendered the subs with MaestroSBT as .son+.bmp's, they look fine, two colors are there (outline and text)
- import them into DVDlab Pro, have the subs rendered with setting "Vector Smooth", subs render OK
- compile the DVD and: The subs are there, work correctly, BUT all black, i.e. outline and text!
So far I often got reversed coloring, outline white, text black, but this is new to me. In the first case I use pgcedit to adjust the CLUT-colors and have just to exchange black and white - this time: no go!
I looked in 'Project Properties', color palette seems to be the usual (default) one, in pgcedit as well after compiling it looks OK.
I can solve the problem with DVDSubEdit and I did of course, but I would like to know what went wrong in DVDlab Pro... The black subs in DVDSubEdit show a CLUT with green "b", "p" and "e1" and "e2" (i.e. three of four rectangles) black, changing those gets me the coloring for the subs I want, but why is it that I can't find this setting either in pgcedit or DVDlab Pro itself?
Any suggestions? Thanks in advance. 8)
You might be better off asking on the Mediachance DVD Lab Pro forum at http://mmbforums.com/ipb/
"Just another sheep boy, duck call, swan
song, idiot son of donkey kong - Julian Cope"
DVDLAB+Runtime Error+Compile.aux
By icemanatvcd in forum Authoring (DVD)Replies: 6Last Post: 27th Mar 2014, 07:08 -
import chinese subtitle to dvdlab pro
By pcb in forum SubtitleReplies: 1Last Post: 18th Dec 2010, 12:02 -
Compile VCD movies plus subtitle into one DVD
By GeekyChocolate in forum Newbie / General discussionsReplies: 5Last Post: 26th Feb 2009, 08:14 -
Subtitle problem with DVDLab Pro
By carlmart in forum Authoring (DVD)Replies: 3Last Post: 21st Nov 2008, 10:18 -
DVDLab Pro 2 compile issues
By milofhead in forum Authoring (DVD)Replies: 3Last Post: 28th Oct 2008, 00:25
