  1. Hi all,
    I just finished recording a 3 hour program, with Windows Movie Maker (Vista), in AVI format. I then went straight into DVDFlick and converted it to DVD format.
    Problem is though, playing it back, its got all lines all over it, im pretty sure its Interlaced.
    Whats a good program that will turn this interlaced 30gb file into a smooth looking dvd?
    Apr 2004
    Miskatonic U
    What did you watch it back on ? If it has been encoded and authored properly then you should not see the interlacing on your TV.
    Read my blog here.
  3. I'm a Super Moderator johns0's Avatar
    canada
    If its on your computer depending on the player it will show interlace lines and thats normal.
  4. oh! ok thanks!
