Hi
I'm having a little trouble. I have a TS. file that I'd like to convert to MPG2, I used various programmes to do this, but for some reason after conversion the picture is grey and the picture is flickering, but there is sound.
The TS. file itself plays well, it's just after it's been converted.
Can anyone advise me please ?
Thanks in advance
Results 1 to 18 of 18
What did you use to convert the TS? I'm assuming that the TS already contains an MPEG2 stream (but as minidv2dvd asks, please post what gspot says, just so we can be sure). That said, MPEG Streamclip usually does a great job of converting TS into "normal" MPEG; it's just a file format change, so no encoding takes place (so it's fast, and there's no quality loss). You can also ignore any complaint about needing the Apple MPEG2 component; that's needed only if you need to play the clip with Streamclip. It will still convert it correctly without this.Originally Posted by DuBsTaR
Cheers guys. I will look into it and post back the info. I'll give the other software you mentioned a try first.
Yes, it looks like Streamclip ain't going to do it for you. As the others have already noted, you will have to do a full transcode into MPEG2.
Instead of making us guess, tell us what you have already tried, including what settings you used, etc. AND what you used to play the result. Sometimes what you think is a problem with the source is actually a problem with the playback software, or vice-versa. The more you tell us, the more likely it is that we can give you a good answer. -
the easiest thing to try is to click video select dvd, click audio select ac3, click format select mpeg-ps(a+v). then click save video and let it convert it.
Excellent, it's managed to convert, only being that it's playing in slight slow motion and the audio is there playing fine. Any ideas ?
did you convert to 25fps? check under video->frame rate in avidemux.
Or if you are converting to dvd then use convertxtodvd or dvd flick(free) or FAVC (FREE) and load the ts, convert, burn, done.
Problem burning .avi file to dvd.. Burner tells me file is too big when not
By accesskb in forum Newbie / General discussionsReplies: 17Last Post: 6th Mar 2012, 19:28 -
changing ifo file names on same file ext of diff dvd files
By holliquinn in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2008, 06:02 -
toast won't do wav, so using mpg file instead of m2v file gets round that?
By jboyd in forum ffmpegX general discussionReplies: 12Last Post: 16th Nov 2007, 15:08 -
question about how to use cue file to break big audio file into tracks
By jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40 -
Converting VOB file to MP4 file. Video is perfect, audio is nonexistent.
By jdfrosty in forum ffmpegX general discussionReplies: 6Last Post: 17th Jul 2007, 19:31
