In the Videoguys site and some others, the nvidia quadro FX 1700 card is
the one to aim for video editing . This card is out of my price range
and I am also not sure I need it in a ~ $1200 system for family
movies editing and some Photoshop [ no game playing].
The step down card is the new 580 Does anybody tried it out
or the previus 570 ?
Should I go for that or for something like a 9800 card ???
Anybody know which 23-26" monitor to get ?
Results 1 to 12 of 12
The quadros are used by pros for heavy effects editing applcations which use wireframe assists and hardware filtering assists. Also the pros are working with 10bit/component or higher log bit depths and work in real time for editing. There is little advantage and a heavy cost penalty for use of these cards for normal NLE home editing.Originally Posted by Dash1
There is a trend to GPU assist for filtering or effects tasks but this area is developing fast and current cards will rapidly fall behind. You need to have an immediate need for these features because you are buying expensive rotting fruit.
http://www.engadget.com/2008/10/17/nvidias-quadro-cx-gpu-optimized-for-people-who-dont-suck-at-ph/
For normal home editing and Photoshop, your money is better spent on a medium level GeForce card (with PureVideo HD) and spend the rest on more CPU.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I did a lot of research into this recently, asked a lot of questions here, spoke on other forums, even spoke to NVidia themselves and the Quadro range is entirely overkill for what you are going to be doing. The High-End (even mid-range) GeForce consumer cards will be fine for what you want to do.
260gtx would be a good card to get,under $200.A 9800gt would be about $100 or less.
Thanks guys ! This card can be found for less then 200.. Does this change your verdict ?
If not, what card specificly? -
Depends if you are rendering OpenGL 3D or CAD. The 580 is a low end OpenGL card.Originally Posted by Dash1
I use the BFG GeForce 9800GT. Cost me $89.Recommends: Kiva.org - Loans that change lives.
Very little 3D and no CAD or games.
What specific card model would you guys go for ?
Regarding the storage, I was thinking of 2 HD's but not in RAID:
One for Win. and other softs and the other for edits .
Any thought on that too ??? -
Only reason to go above the 9800GT or equiv ATI would be for gaming.Originally Posted by Dash1
Yes OS drive and separate video drives. Start with one video drive. Soon you will have ten. So get a case with a large PS and room for more drives.Recommends: Kiva.org - Loans that change lives.
So that's what happened to meOriginally Posted by edDV
Having the OS/apps separate from the rest of your files/data is always a great idea. It's a bare-minimum requirement of systems I build for home users. The OS drive can be smaller and with how cheap storage is it's easy to get a big secondary drive.
If you aren't gaming or doing much like that I would maybe look at one of the mid- or low-end GeForce 9 series with passive cooling. One less fan in your case is always nice when you don't need it. I think there are some 9600s and 9400s which have passive cooling. Just check to make sure they support PureVideoHD so that you can get a little hardware decryption performance when playing back video. You'll also want to make sure it supports what displays you want to use. Are you going to run two DVI displays? HDMI?FB-DIMM are the real cause of global warming -
I will be using one 24" for starter
Do I need my HDD's with 32 mem.???
For the graphics ,Is this a good choice ?
XFX GS250XYDFC GeForce GTS 250 512MB Core Edition 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail -
A large buffer isn't required for your HDDs. It helps sometimes but I doubt you'll notice it.
You can probably get a cheaper card that a GTS250 to support what you're doing. Like I said: if you're not gaming get a mid- to entry-level card with passive cooling. Otherwise that card you posted should do everything you need it to do.FB-DIMM are the real cause of global warming -
I go w/ all TB+ drives now, w/ their high-density they get 100MB/s+ "sustained average transfer rates" w/o RAIDOriginally Posted by Dash1
Seagate Barracuda 7200.11 1500GB 32mb sata2 drives got a rep for bad firmware, it has since been resolved but they still sell them for cheap, about $130USD, I have (4) and have never had a problem w/ mine (3 of those 1500GB dries are full lol)
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148337
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html
Need another graphics card already!
By A Traveller in forum ComputerReplies: 15Last Post: 26th Sep 2011, 16:07 -
Very Weird issue with Capture Card and Graphics Card? Please help
By Ps3riiper in forum ComputerReplies: 9Last Post: 11th May 2011, 15:51 -
need a new graphics card..
By SE14man in forum Newbie / General discussionsReplies: 11Last Post: 28th Dec 2007, 01:50 -
What sort of Graphics Card/Capture Card to get
By Dr_trout in forum Capturing and VCRReplies: 4Last Post: 24th Jul 2007, 15:19 -
Graphics Card Question?
By taker36904 in forum Newbie / General discussionsReplies: 3Last Post: 5th Jul 2007, 10:03
