Hi all,
After successfully dubbing handycam film onto laptop, then again successfully extracting time/date using DV_DateCode - I am now having trouble dubbing that film with date/time onto DVD. I am using DVD Maker software and when I try to add it - it boots me out with 'close program'. I am using a Sony Vaio Laptop - Vista software. If anyone can help I sure would appreciate it.![]()
Hey guns1inger,
In DVD Maker it asks you to ADD the file you want to copy...when I do this the program closes. -
I doubt that DV_datecode has done anything to the original file. If you have created an SRT subtitle file with DV_datecode then you could use something like AVStoDVD or DVD Flick to create the DVD instead.
I have not used DVD Maker, so I can't help you with that product, unfortunately.Read my blog here.
Hey Guns1inger,
There is no problem with playing the footage with the date and time from DV_Date on the laptop - The problem now is that I cannot burn the footage date/time included to dvd -
And again, what happened in the other two programs ? If they gave you error messages this may help point to the problem.
I would also like to see a mediainfo output just to confirm what you are working with.
There is a difference between a video that can be played back, and a video that can be re-encoded. Some players are designed to play back broken video, however the same video may not be suitable for encoding because it is broken.Read my blog here.
mts file datecode
By mpegjohn in forum ProgrammingReplies: 3Last Post: 7th Jan 2012, 09:48 -
Extract datecode from HDV to subtitles
By yaroslavp in forum Newbie / General discussionsReplies: 1Last Post: 4th Jan 2012, 16:13 -
How to stamp DateCode on DV files...
By FatBoy123 in forum Newbie / General discussionsReplies: 4Last Post: 24th Jun 2011, 08:06 -
inlay datecode on AVCHD
By jjblackisback in forum Video ConversionReplies: 10Last Post: 4th Apr 2011, 14:44 -
Windows Media Player - DV Datecode?
By chainz in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th Jun 2007, 09:41
