hi y'all!
i'm posting this to newbie cuz i'm pretty sure it's a basic question!
i have a dell xps m1530 laptop and today for the first time i've connected it to my vizio VA19L hdtv, using an hdmi cable.
picture quality is awesome, but i get no audio transfer from the laptop to the tv.
Wasn't hdmi supposed to be only one connection for both audio and video?
eligen
__________
the only thing necessary for the triumph of evil is the good man to do nothing. -
You should get audio 'if' your laptop supports audio out through the HDMI connector. If you were just using a DVI>HDMI cable or adapter, no.
I would check your audio card settings as audio out through HDMI may not be selected. And the TV settings to make sure it's selected there also. -
The HDMI standard supports audio and bi-directional control but implementation is optional by device. Check the specs.
http://www.kiva.org/about -
hey redwudz & edtv, thanx 4 ur quick reply.
so i'm using an hdmi to hdmi cable; i checked on the tv and it seems it's selected.
at a certain point i thought the problem might be that i was using the hdtv in extended desktop mode, but that wasnt it eiither.
i'm beginning to think that the audio card on my laptop does not support hdmi audio out. im gonna check with dell.eligen
__________
When I first connected my laptop to a hdtv with a HDMI the audio was still coming out the laptop speakers. I right clicked on the speaker icon in the bottom right to change the settings (Right click - sounds - playback tab). It worked after I changed it to 'Digital Output Device (HDMI)'.
yep, it worked... but now i'm having the opposite problem trying to revert to the laptop speakers...Originally Posted by bighead321
eligen
__________
For Vista...
Right click on speaker icon then "Playback Devices". You will see a list.Recommends: Kiva.org - Loans that change lives.
of course i've tried to do that... it just wouldnt go back to laptop speakers... in the end i just logged off and logged back on and the sound was back on the laptop speakers... so weird!!Originally Posted by edDVeligen
__________
HDMI cable - from computer to TV, no audio
By Zetti in forum Software PlayingReplies: 15Last Post: 12th Dec 2011, 11:30 -
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 16:33 -
HDMI Cable - Audio ???
By blinky88 in forum ComputerReplies: 8Last Post: 27th Apr 2011, 07:23 -
Suddenly no audio with HDMI cable
By StarDweller in forum DVD & Blu-ray PlayersReplies: 15Last Post: 14th May 2010, 10:45 -
No audio on TV after hooking up laptop with HDMI cable.
By jordy2324 in forum ComputerReplies: 5Last Post: 27th Jul 2009, 19:23
