    Jun 2009
    I'm having problems with ffmpeg when using DVD Flick. It crashes at different points when encoding the video. I have had success with it in the past but now I can't get it to work without crashing. Here is the error log:
    DVD Flick error log
    Version 1.3.0.6 build 734
    Windows 5.1 build 2600 Service Pack 1
    *** Project info
    EncodeProf 2
    Threads 1
    OverScan 0, 3
    TargetRate 0
    TargetFormat 1
    TargetSize 4
    CreateISO 0
    CustRate 0
    EnableBurn 0
    EraseRW 1
    HalfRes 0
    LoopPlayb 1
    AutoPlayMenu 1
    MenuEnable 1
    MenuTemplt Plasma Sphere
    VolumeMod 100
    WhenPlayed 0
    *** Warnings given
    *** Titles
    0 -
        ChaptCount -1
        ChaptInt 5
        ChaptSource 1
        TargetAR 1
        ThumbIndex 558
    *** Project sources
        C:\Documents and Settings\.YOUR-PD3MH0ABGS\My Documents\FrostWire\Saved\????????.avi
        Stream 0 (2)
            Dur 5582.14
            StartT 0
            Compr mpeg4
            BitR 0
            640x358 29.97 FPS
            PAR 1
            SAR 1.787709
        Stream 1 (1)
            Dur 5582.14
            StartT 0
            Compr mp3
            BitR 128
            Chnnls 2
            SRate 48000
            Delay 0
    *** dvdflick.log
    11:55:25 AM: DVD Flick 1.3.0.6 build 734
    11:55:25 AM: Calculating stream sizes...
    11:55:25 AM:     Disc space used : 4312022 KB
    11:55:25 AM:     Average bitrate : 6128 Kbit/s
    11:55:25 AM:     Total duration  : 1:33:02 hours
    11:55:25 AM: 1 title(s).
    11:55:25 AM: Using Normal encoding profile.
    11:55:25 AM: NTSC target format.
    11:55:25 AM: CPU: AMD Athlon(tm) XP 3200+
    11:55:25 AM: Threadcount: 1
    11:55:25 AM: Encoding video...
    11:55:25 AM:     Title 0, source 0
    11:55:25 AM:         Source         : C:\Documents and Settings\.YOUR-PD3MH0ABGS\My Documents\FrostWire\Saved\??????.avi
    11:55:25 AM:         Properties     : 640x358, 1.79:1, 29.97 FPS, mpeg4, 5582.14 seconds
    11:55:25 AM:         Target BitRate : 6128 Kbit\s
    11:55:25 AM:         Re-encoding
    11:55:25 AM:          -i "C:\Documents and Settings\.YOUR-PD3MH0ABGS\My Documents\FrostWire\Saved\?????????.avi" -vcodec mpeg2video -s 720x472 -padtop 4 -padbottom 4 -r 29.97 -g 14 -bufsize 1835008 -packetsize 2048 -muxrate 10080000 -aspect 16:9 -minrate 6078k -maxrate 6078k -b 6078k -preme 1 -precmp 2 -subcmp 8 -mbcmp 8 -cmp 1 -sws_flags lanczos+accurate_rnd -mbd 2 -sc_threshold -3000 -dc 8 -an -threads 1 -fflags +genpts -f mpeg2video -shortest -map 0:0 "C:\Documents and Settings\.YOUR-PD3MH0ABGS\Desktop\??????\0.0.m2v"
    12:15:06 PM: Combining video sources...
    12:15:06 PM:         Concatenating video...
    12:15:06 PM: Encoding audio...
    12:15:06 PM:     Title 0, track 0, source 0 of 0
    12:15:06 PM:         Source     : C:\Documents and Settings\.YOUR-PD3MH0ABGS\My Documents\FrostWire\Saved\??????.avi
    12:15:06 PM:         Properties : 2 channels, 48000 Hz, mp3, 5582.14 seconds
    12:15:06 PM:         Recompressing to 192 Kbit\s with 2 channel(s)
    12:15:06 PM:          -i "C:\Documents and Settings\.YOUR-PD3MH0ABGS\My Documents\FrostWire\Saved\??????.avi" -i "C:\Documents and Settings\.YOUR-PD3MH0ABGS\Desktop\????????m2v" -map 0:1:1:0 -acodec ac3 -ab 192k -ac 2 -ar 48000 -threads 1 -async 0 -shortest "C:\Documents and Settings\.YOUR-PD3MH0ABGS\Desktop\??????\0.0.0.ac3"
    *** ffmpeg_audio_title0_track0_source0.txt
    'C:\Documents and Settings\.YOUR-PD3MH0ABGS\Desktop\??????\0.0.0.ac3':
        Stream #0.0: Audio: ac3, 48000 Hz, stereo, s16, 192 kb/s
    Stream mapping:
      Stream #0.1 -> #0.0 [sync #1.0]
    Press [q] to stop encoding
    size=     298kB time=12.74 bitrate= 192.0kbits/s
    size=     613kB time=26.14 bitrate= 192.0kbits/s
    size=     947kB time=40.42 bitrate= 192.0kbits/s
    size=    1272kB time=54.27 bitrate= 192.0kbits/s
    *** ffmpeg_video_title0_source0.txt
     715173kB time=963.96 bitrate=6077.7kbits/s
    frame=28913 fps= 43 q=2.0 size=  715717kB time=964.70 bitrate=6077.7kbits/s
    frame=28935 fps= 43 q=2.0 size=  716262kB time=965.43 bitrate=6077.7kbits/s
    frame=28958 fps= 43 q=2.0 size=  716831kB time=966.20 bitrate=6077.7kbits/s
    frame=28979 fps= 43 q=2.0 size=  717351kB time=966.90 bitrate=6077.7kbits/s
    frame=29002 fps= 43 q=2.0 size=  717921kB time=967.67 bitrate=6077.7kbits/s
    *** Project destination folder
        0.0.0.ac3	1370880
        0.0.m2v	735150607
        dvdflick.log	2502
        errorlog.txt	5695
        ffmpeg_audio_title0_track0_source0.txt	2458
        ffmpeg_video_title0_source0.txt	107961
    *** Drives
    A - not ready
        C -  - 2
        FS NTFS
        AvailSpace 92611
        FreeSpace 92611
        TotalSize 152625
    D - not ready
    E - not ready
    F - not ready
    G - not ready
    H - not ready
    I - not ready
        M -  - 2
        FS NTFS
        AvailSpace 2531
        FreeSpace 2531
        TotalSize 38154
    If anybody can help me with this it will be greatly appreciated. Thanx.
  2. welcome to the forum. not a good start though. you need to edit out the name of that source video. it will only cause problems.
