on the left side of the screen is a link to a section of the site called tools. in there you will find all sorts of useful tools. for you the subsection to try is authoring (dvd).
i might go with - Simple DVD Creator - but there are other free ones you could try also. -
I have TMPGNC DVD AUTHOUR on my PC and i have tried using that, only i have a problem. The problem is, there are 2 mpeg files i want to put onto a DVD. the first opens fine into DVD AUTHOUR but the second gets an error message. The first file is exactly the same as the second, but the first opens on DVD AUTHOUR fine, any ideas what the problem is and how i can get round it!!!
The picture is the error message that DVD AUTHOUR displays!!
Some flag is messed up on your mpeg files.
A cheap trick to bypass this, is to patch your files with DVDPatcherLa Linea by Osvaldo Cavandoli
Conversion of video to mpeg 7 xml
By Rimaz in forum ProgrammingReplies: 2Last Post: 2nd Apr 2012, 14:29 -
.dv movie project conversion to MPEG-2 with video text
By RL in forum ffmpegX general discussionReplies: 1Last Post: 30th Jan 2011, 17:39 -
TMPGEnc & EO Video mpeg-2 conversion problems
By jtalpur in forum Video ConversionReplies: 2Last Post: 28th Aug 2007, 15:46 -
MPEG 2 Conversion to DV Video ruins aspect ratio
By dyoungiii in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 31st Jul 2007, 18:59 -
Batch conversion (Mpeg to Windows Media Video)
By The Fred in forum Video ConversionReplies: 11Last Post: 12th May 2007, 09:36
