I have a BlackmagicDesign Intensity Pro card, and I'm going to capture my hdmi signal from my camera.
I bought Microsoft Expression Encoder 2, but this software is not compatible with the card.
So I'm looking for other software that captures my hdmi signal to a high quality wmv format. Does somebody know good software for doing this ?
The enclosed MJPEG codec is normally used. Better is Cineform. Or you can add a huge RAID and capture uncompressed.Originally Posted by CoNiO
Then encode to wmv non-realtime.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
I usually capture with the blackmagic's encoding software to avi then import into TMPGENC Express 4. Or I use Adobe Premiere CS3 and capture directly to the MJPEG Codec they provide. Again thou i dont think you're going to be able to do a simple one stop shop solution with any software to get it to WMV. I could be wrong on this one, however i have been using the Black Magic card for a while now and have solved almost every problem in the book with it as far as encoders/decoders/capturing softwares go. So feel free to as me anything you need. By the way good choice of capturing card!! I love mine.
Blackmagic Design Intensity Pro (PC GAMEPLAY RECORD)
By TommyGun in forum Capturing and VCRReplies: 23Last Post: 19th Oct 2011, 07:31 -
Blackmagic Design Control Panel
By Norwalk2006 in forum Capturing and VCRReplies: 1Last Post: 14th Sep 2011, 18:32 -
Blackmagic Design Video Recorder
By Rawit in forum Capturing and VCRReplies: 0Last Post: 31st Aug 2010, 03:41 -
Good avi encoder?
By The.King in forum Newbie / General discussionsReplies: 5Last Post: 15th May 2010, 12:33 -
Fastest but good quality mpeg-2 encoder
By cd090580 in forum Video ConversionReplies: 12Last Post: 23rd Jun 2007, 12:42
