In working with a neighbor using winxp pro he has lost all of his customizing. He was using the Windows Classic theme and it appears to be completely missing. What he has looks similar to the Vista theme. All attempts to go back to the classic theme have failed. Even system restore did not work. Does anyone know anything about this problem?
Try this: Control Panel -> System -> Advanced -> Performance settings -> select Adjust for best performance
and save theme
Thanks for trying but it didn't work. Any attempt to get classic back results in an error "Visual themes not available"
The only color themes available are green blue nad silver. All the classic stuff seems to have been deleted. As mentioned before the various windows look very much like Vista. -
Format the computer and start over.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Need only Perform a Windows XP Repair Install without format.Originally Posted by Dv8ted2
He might not even have to do that, I think themes falls under "windows optional components" in XP, just put the Windows installation CD in and go to "disc cleanup", and then go to install/delete windows optional componentsOriginally Posted by roma_turok
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
http://www.kellys-korner-xp.com/xp_abc.htm
Down to
Themes (Won't Load or only Windows Classic is listed)
Follow -
When you get everything the way you want it, and to preclude this kind of problem, and others, make an image backup to an external HD.
Sony DCR-TRV18 MiniDV and WinXP Pro SP3
By zoomie in forum Newbie / General discussionsReplies: 4Last Post: 30th Aug 2009, 15:31 -
Registry Cleaner for WinXP Pro...
By retroborg in forum ComputerReplies: 5Last Post: 17th Oct 2008, 11:53 -
Solid State HD for WinXP Pro / Vista boot installation….
By retroborg in forum ComputerReplies: 2Last Post: 12th Oct 2008, 15:09 -
Best/Ideal HD partitioning for a new WinXP Pro installation
By retroborg in forum ComputerReplies: 4Last Post: 12th Oct 2008, 09:45 -
WinXP Media Center license on XP pro possible?
By silverbullet99 in forum ComputerReplies: 7Last Post: 15th Jun 2007, 12:13
