Trying out my new Humax which claims you can record 2 programmes at the same time.
Tried this from the epg using 2 programmes one above the other but when 2nd programme is selected it says I cant do it as there is already 1 programme scheduled. Am I missing somethingThe HDR is connected to a quad lnb with twin cable.
According to the specs that I can find, they don't state that you can record to programs. The specs state recording channel while watching another.
Google is your Friend -
The Humax web site clearly says record two channels at the same time.
http://www.humaxdigital.com/freesat/specifications_FOXSAT-HDR.asp -
I Assume it has two tuners therefore it should record two channels but you would have to watch one of the channels it is recording. my Freeview recorder does that, while my cable recorder has 3 tuners which can record two whilst watching another. That link you posted does say it will do that. But not much more. what about the manual, does it say anything else.
Thanks John.
That would explain it. The instruction book does not make that point very clear.
Was trying to set up 2 recordings from EPG
11 Programmes used - still can't join mp4 successfully?
By The.King in forum EditingReplies: 20Last Post: 13th Oct 2012, 03:32 -
Sony HDR-XR160 I want to live record to a DVD recorder with quality picture
By Sparkiewalt in forum Newbie / General discussionsReplies: 13Last Post: 29th Mar 2012, 08:40 -
Can you recommend a easy to use programme to record bbc 6 programmes?
By Ilovethebbc in forum AudioReplies: 2Last Post: 18th Apr 2011, 10:56 -
hdr sr12(NTSC) or hdr sr12e(PAL) any difference between them?
By deejay.2001 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Aug 2008, 17:28 -
Downloading films/tv programmes
By DrAlanStatham in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jun 2008, 20:07
