Got a problem
when i convert a divx movie (ntsc) to mpeg videocd (pal)
i get a schok motion effect... .
The movie stops every few seconds for 1/10 of a second en than go's on.. the whole movie along...
sound of the divx is converted to a .wav file converting from 48000 Hz to 44100 Hz.
whit a dvd rip no problems?
Please HEEEELLLLLLLLLP
I get exactly the same problems..
I've tried several different settings, but I cannot get it right in any way.
VCD's works flawlessly....
I'm going for LSX mpeg encoder now.... We'll see if things work out better.[/quote] -
How did you convert the NTSC DivX to PAL VCD? How did you change the framerate? What is the bitrate? Is your player CD-R compatible?
the vcd is not direktly the problem... the converted avi to mpg file is having the problem.The vcd is the same as the
mpg file.
no problems with the same setting wen i do a dvd rip.
The settings i use are those i load in as a pal template from tmpgenc itself!
Vegetables -
I get this stuttering problems when I convert DivX that have a frame rate that is below that of PAL VCD/SVCD.
For example, many DivX has 23.976fps.... Perhaps the problem has something to do with the increase in framerate (to 25fps)?
I've never changed the framerate prior to using TMPGEnc to make the SVCD... Should this be done first in another application? Or have I missed a setting somewhere in TMPGEnc?
Like Dagger38 I just load the template and only change the bitrate... and motion search precision to High Quality.
And a correction to my previous post... The problems DO occur on VCD's as well.... Noticed that today... -
..framerate conversion problem. If you had searched this site you had found this:
http://www.vcdhelp.com/phpBB/viewtopic.php?t=76803&highlight=ntsc+pal
http://www.vcdhelp.com/phpBB/viewtopic.php?t=77629&highlight=ntsc+pal
http://www.vcdhelp.com/phpBB/viewtopic.php?t=76832&highlight=ntsc+pal
http://www.vcdhelp.com/phpBB/viewtopic.php?t=71671&forum=3
http://www.vcdhelp.com/phpBB/viewtopic.php?t=70563&forum=3
http://www.vcdhelp.com/phpBB/viewtopic.php?t=78178
Does Tmpgenc Authoring works 4 support motion background menus?
By perfection in forum Authoring (DVD)Replies: 1Last Post: 10th Mar 2011, 03:35 -
TmpGenc Authoring Works 4 - Motion Menu Question
By blazin-j in forum Authoring (Blu-ray)Replies: 3Last Post: 18th Oct 2010, 11:00 -
TMPGENc Authoring Works 4 - motion menu no audio
By mobie29 in forum Authoring (Blu-ray)Replies: 3Last Post: 16th Jul 2010, 17:32 -
Best tool for PAL to NTSC without jerky motion...using TMPGenc
By funkymix in forum Video ConversionReplies: 3Last Post: 15th Mar 2009, 12:59 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11
Got a problem
