I'm having trouble merging movies that have been broken up into 3 part AVI files. I want them to be one big continuous file. Merging 2 parts is always fine, but adding the third always seems to cause sync problems. I ususally use VDub-MP3-Freeze. Can anyone recommend a surefire solution?
I assume you are using "append segment" to join the three files and save as one large one.
How about joining just the first two, then saving. Load that file up and add the final part, see if that solves the sync problem.
Sync problems can happen when the original files have not been cut on a key frame.
AVI Merge (XviD)
By Asesinato in forum Video ConversionReplies: 5Last Post: 19th Apr 2012, 05:37 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41 -
Two video files merge but only part 1 can be viewed... need help!
By Djard in forum Newbie / General discussionsReplies: 2Last Post: 28th Mar 2011, 13:49 -
Two XVID, Two Sub/IDX - How to merge?
By Makdaddy in forum Video ConversionReplies: 1Last Post: 14th Sep 2009, 09:21 -
merge avi and wav
By zootedlooter in forum EditingReplies: 2Last Post: 21st Dec 2008, 13:11
