OK, it's been a while since I used this program, but what I was doing was making a DVD where I added the chapters in DVDSP as it was one long chapter before.
Here is what I did:
I ripped to a single VOB in Mac the Ripper
Demuxed to .M2V and .aiff in MPEG Streamclip (The original audio actually was PCM)
Imported into DVDSP
Set up menus to go with the new tracks I created on the timeline
Worked fine in Simulation Mode
When I went to burn, I did build and format like I always do and it said I had set my bit rate too high.
Why is it trying to reencode? Why would I need to set a bitrate? I never had to do that in DVDSP 2. It's already been encoded into MPEG 2. I just want to make a DVD of it.
Normally, if I capture video myself, I do it in Final Cut pro where it adds the chapters on its own. Aside from adding the chapters in DVDSP, I do it exactly the same way and when I go to build and format, it builds and formats with no issue.
How do I fix this?
	No matter what I do, it says video bit rate too high in DVDSP. Here is what MPEG Streamclip had to say about the resulting files
 Type: MPEG elementary stream
 Duration: 0:55:44
 Data Size: 3.10 GB
 Bit Rate: 7.95 Mbps
 Video Tracks:
 224 MPEG-2, 720 × 480, 4:3, 29.97 fps, 8.00 Mbps, lower field first
 Audio Tracks:
 160 PCM stereo, 48 kHz, 1.54 Mbps
 Stream Files:
 New Title 1 (Ch1 - Ch1).m2v (2.33 GB)
 New Title 1 (Ch1 - Ch1).aiff
	DVD Studio Pro likes AIFF and AC3 audio.
 If I had to guess as to what happened, Your bitrate was too high
 FOR THE TARGET DISC SIZE, not necesarily that your bitrate was too high.
 Think about it, if you ripped originally from MTR and just demuxed in
 MpegStreamclip, then you probably were going from a DVD-9 ( up to
 8GB in size) disc, and your DVD Studio Project was set for a DVD-5
 (up to 4.37 GB in size).
 A quick look at the original disc by inserting it into MTR and looking at
 the total output of the ripped Title would confirm.
 How to have gotten around this would have been to set DVDStudio Pro
 to a DVD-9 project, brought in your assets, set your chapters,
 and then mux the assets ( what DVDStudio Pro has to do,
 as assets don't always have to be re-encoded, but have to be muxed)
 to a target of DVD-9. You might have ended up with say around
 a 5.1GB disc, certainly more than 4.37GB, but then there would have
 not been any re-encoding of audio.
 Once the DVD-9 folder is created, you could then safely use
 DVD2ONEX to shrink it to fit to a DVD-5, and then burn that
 output to disc using Toast."Everyone has to learn, so that they can one day teach."
 When I'm not here, Where can I be found?
 Urban Mac User
	Actually, it came from a DVD-5. Total size of the .M2V and the .AIFF after demuxing was 3.2GB, so I don't know why it didn't fit. Played fine in preview
 I saw online somewhere where someone with an older version of DVDSP had this issue and had to go in and manually chnge the encoding settings on the asset. Doesn't seem like you can do that on 4.2.1.
 I know stuff has to be muxed. I just didn't want a reencode, which is what I thought DVDSP was doing.
	try 42-46pps of the DVDStudio Pro Manual..... Looking back at your post,Originally Posted by jabbo5150
 we've been discussing SIZE OF THE ASSETS, (3.2gb)
 but not the ACTUAL BITRATE USED TO ENCODE to MPEG-2.
 Forget about the original disc's encoding and let's just concentrate on what DVDSP is trying to do:
 Your video, as listed in the original posting is already at a bitrate of 7.95MBPS ( VERY HIGH!)
 Your audio is uncompressed AIFF .
 If you take our favorite "Bit Rate Calc"
 and input these variables you'll get the following:
 As you can see for both your assets muxed, it should target about 9.6MBPS.
 Your current assets are at 9.154 ( 8.0 + 1.54), so in theory they should fit to disc.
 DVD Studio Pro's standard max threshold it allows is 9.2MBPS for DVD-5 discs.
 So on just assets alone, you are NEAR DVDSP's max threshold.
 So what could be causing you to hit over the 0.046MBPS....
 My guess would be your MENUS...A High Res still picture,
 video or audio playing on the menu, or if you are doing
 MAIN MENU +CHAPTER MENU, the combination of the two
 is what is throwing out your authoring.
 ( It's also probably why your original disc was NO FRILLS,
 they sacrificed multiple menus and chapters for HIGHER QUALITY PLAYBACK)
 THe DVDSP manual even talks about this...that you should after figuring up
 your bitrate, subtract 1.5MBPS for Menus ( Main, Chapter, First Play, etc)
 from the target of your video to insure it meets the 9.2 max set by DVDSP.
 Now PCM is one way to address it as you found out. Another is
 you could have dropped the audio to 128 using Audacity or
 Amadeus II. Another way would have been to have DVDSP re-encode
 the video asset to slightly less than 8.0, say 7.0.
 So that's the mystery!"Everyone has to learn, so that they can one day teach."
 Urban Mac User
	That makes sense. I did add a menu and a sub menu, though they were pretty basic. This also would explain why it fit just fine when I converted it to .ac3. Thanks for the help
	u r welcome! "Everyone has to learn, so that they can one day teach."
 Urban Mac User
  Avid Studio vs. Sony Vegas Pro/StudioBy HoosierGuy in forum EditingReplies: 12Last Post: 8th Dec 2011, 21:06
  [DVD Lab Pro] subtitles wrong timeBy dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42
  Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50
  DVD Studio ProBy macuser1960 in forum MacReplies: 3Last Post: 12th Mar 2009, 08:45
  dvd studio pro subtitleBy sedio in forum MacReplies: 1Last Post: 4th Apr 2008, 10:21
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
