About the temp. results in Speedfan, appreciate advise on what temp. 4 is relating to. It would seem it is not relating to the CPU (fan 1) ???
1 = CPU
2 = Motherboard
3 = HDD
4 = ???
Cheers from downunder to all.
Results 1 to 11 of 11
The readings you see in Speedfan depend on the motherboard you have. Some boards will show the CPU temp with temp3, others temp1... Also, not all ports on the hardware monitor chip, are used. The ones that give impossible values are the ones that aren't used. If you're not sure which is the CPU temp, just check with the BIOS' PCHealth.
As for your temp4, click configure and look under core temp. That's the reading from the built in CPU sensor and comes from the ACPI temp in your image.
Look at the voltages tab, you can remove the negative voltages from the listing, ATX power supplies don't have negative voltage rails. -
The temp. shown under fan 1 is the CPU.
The temp. under fan 2 is the mobo.
Temp. under HDD is self explanitory.
The last temp. noted as fan 1 has got me stumped. -
the 4th one is most likely the acpi temp. the southbridge possibly.
Yes they do. Usually a -12VDC and sometimes a -5VDC. But may be not used much anymore except for analog audio outputs and some types of logic circuits. (2002 v1.2 made -5VDC optional , 2004 v2.01 removed from specification) http://pinouts.ru/Power/atxpower_pinout.shtmlOriginally Posted by nic2k4
Other devices that sometimes have sensors are the GPU (Video card), though it's often 40C - 55C, so may be easy to recognize.
I find HWMonitor a lot easier to use, though Speedfan is more flexible: http://www.cpuid.com/hwmonitor.php -
for cpu temps i like coretemp - http://www.alcpu.com/CoreTemp/
core temp is used for 65nm cpu's like Conroe E6400, E2160.
real temp is used for 45nm cpu's like the Wolfdale's E8400, E8500 & E8600. -
You might have 2 core temps shown for core 1 and core 2 just like you have 2 cpu voltage readingsOriginally Posted by blinky88
temp 1 = cpu core 0
temp 2 = cpu core 1
temp 3 = HDD
temp 4 = NB
note: the disparity in voltage would explain the difference in temps across the die (if my theory is acurate)
ocgw
peacei7 2700K @ 4.4Ghz 16GB DDR3 1600 Samsung Pro 840 128GB Seagate 2TB HDD EVGA GTX 650
https://forum.videohelp.com/topic368691.html -
I gotta ask is this PC in an A/C room ( or maybe a cave ;) ) or are you using some form of active cooling? 'Cause if you are getting readings that are lower than ambiant temp, they're un-reliable. In which case,I would switch to the Core Temp reading (ACPI reading) for the CPU temp. That's the temp4 reading you're asking about.Originally Posted by blinky88
Hi Nic,
It's winter downunder, bloody cold .... thanks for clearing that up for me.
The CPU is a P4 2g socket 478.
Many thanks to all who responded, appreciated. -
Hi again Nic,
After a google search and reading MANY comments about Speedfan and what the various temp's relate to, no-one ..ie.. outside of yourself think the ACPI temp is the CPU core temp, in fact, from what I have read, most think it relates to some chip on the M/B although no-one really knows. ACPI (Advanced Configuration and Power Interface) hard to see how this relates to the core temp ?
RipBot264 Temp Folder
By jotpilot in forum Blu-ray RippingReplies: 12Last Post: 11th Jan 2012, 16:45 -
Computer Meltdown & Speedfan Readings
By Tom Saurus in forum ComputerReplies: 11Last Post: 22nd May 2011, 14:04 -
CPU Temp.
By HotDamn! in forum ComputerReplies: 33Last Post: 8th Mar 2010, 13:21 -
Processor Temp Help
By mikayd in forum ComputerReplies: 9Last Post: 29th Dec 2008, 21:01 -
CPU Temp
By Willy5157 in forum ComputerReplies: 4Last Post: 9th Feb 2008, 20:22
