Hi I've got a Philips DVP5160/12 player and I want to know is it possible to add new divx codecs. Can someone explain the procedure if it's possible, thanks.
	No, it isn't possible.
 On set-top players, the decoding is generally done in hardware, so you'd most likely have to actually physically modify the hardware, which isn't really advisable.
 What do you mean by 'add new divx codecs'? There's only really one codec (DivX/Xvid), unless you want to add support for DivX/Xvid features your player doesn't support, like DivX Ultra, or even the new h.264 support in DivX (which, again, is highly unlikely to be possible with a set-top player unless it supports it out-of-the-box).If cameras add ten pounds, why would people want to eat them?
	By add new divx codecs i meant installing new versions of these codecs as you said h264. I've found that some video material that is divx is not supported on my player, I get audio but not video. Thanks for your help.
	If the video doesn't play then it hasn't been encoded in a manner compatible with your player. The only solution is to re-encode it correctly. Try AVI Recomp Read my blog here.
  Multiple Divx codecs?By Huh...What? in forum Video ConversionReplies: 15Last Post: 16th Dec 2009, 09:44
  Divx Ultra .divx files on philips DVP5140By marioval in forum DVD & Blu-ray PlayersReplies: 4Last Post: 11th Nov 2009, 12:45
  Xvid and Divx CodecsBy Jomapil in forum Newbie / General discussionsReplies: 2Last Post: 29th Jan 2009, 11:42
  Philips DCP850 DivX overall quality (and DivX subtitle handling) question!By mabhz in forum DVD & Blu-ray PlayersReplies: 0Last Post: 3rd Jul 2008, 19:59
  BIOSTEK XS-260 or PHILIPS DVP5160?By SamFisher199 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 31st Dec 2007, 10:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
