Hello, I just downloaded and installed ffmpegX. I need to make some movies for the Uni. I start from a series of images (I can make those in any format), and I want to produce a movie that can be seen in Mac/Windows and possibly also linux.
The images are about 1000, and depicts graphs, so should be possible to compress them well.
How can I do it?
Can it be done at all with ffmpegX? If not with this, what other program should I use?
I actually need something that is easy to install and that can be commanded from the command line, so to do it from inside a python script.
Many thanks,
Pietro
The image represent an example of the images I need to link together.
l_organizations.pdf
I would use ffmpeg (not ffmpegx) or mencoder, see http://electron.mit.edu/~gsteele/ffmpeg/
So the Circles in the PDF each represent an image ( PSD, TIFF, JPG)
and you want to link them into linear fashion in a program
that will then generate a movie file that can be shown
on the web, on a computer, or via email?
Simple:
Use iMovie to place the images into a timeline, in the linear order you want, and then export out as a .mov file."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
make movie with images and transitions
By J@Y in forum EditingReplies: 6Last Post: 4th Nov 2011, 22:35 -
Movie, vs Genre, vs TV series
By Digenes in forum DVD RippingReplies: 3Last Post: 28th Nov 2010, 18:39 -
Back Up of Main Movie/Episodes from a TV Series Disc Using DVDShrink
By TufrThanu in forum Authoring (DVD)Replies: 5Last Post: 15th Nov 2008, 18:47 -
Add subtitles to a series DVD, not just a movie (problems with Muxman)
By gimeis in forum Newbie / General discussionsReplies: 24Last Post: 9th Sep 2008, 02:39 -
I need a guide fot adding subtitles to DVDR of series- not movie
By dallylama in forum SubtitleReplies: 4Last Post: 8th Jan 2008, 21:22
