Have a challenging problem.
Multiple users storing videos into separate folders using different formats - but mostly MP4 (from mobile phones) and 3ivx (Flip video).
I need to convert them all to WMV automatically along these lines without any user intervention required....
1. To run automatically overnight and identify any non-WMV files amongst several specified folders (and any of their subfolders)
2. To convert these to WMV - retaining original resolution & filename - into original file folder (essential). A watermark would be useful.
3. After conversion to delete original file (optional).
4. Ideally to generate log of files converted/problems.
Any ideas??
Tried several demos (Xilsoft Ultimate, Easy Video Convert, Tunebite) but none satisfy above criteria (and Tunebite severely mucked up codecs & crashed explorer).
Windows Media Encoder, see http://www.microsoft.com/windows/windowsmedia/howto/articles/AutomatingEncoding.aspx .You probably need to install codecs like ffdshow to be able to decode mp4, etc.
If that wont work I would try HDConvertToX, MediaCoder....or convert to wmv2 using ffmpeg(through a gui like winff or command line). -
None of these will do what I need without a lot of scripting and as far as I can tell, still won't be able to automatically find files to convert. They all need the files to be specified.
I was really looking for something to do what I need straight out of the box! I'm prepared to pay! -
I don't think you will find any such app without any custom scripting.
Automated video conversion with a "watch" folder(s)
By fender4645 in forum Video ConversionReplies: 1Last Post: 8th Apr 2010, 15:40 -
Recommend a batch conversion program for mkv to wmv?
By yoda313 in forum Video ConversionReplies: 2Last Post: 23rd May 2009, 06:58 -
batch WMV to AVI that will maintain video bitrate and frame dimensions
By chief1972 in forum Video ConversionReplies: 2Last Post: 27th Dec 2008, 13:17 -
Batch tag WMV files?
By xxsunshinegodxx in forum Newbie / General discussionsReplies: 0Last Post: 17th Sep 2007, 12:27 -
Best Batch convert tool for WMV to DIVX
By hsantos in forum Video ConversionReplies: 3Last Post: 28th May 2007, 08:48
