Hi there.
Long time reader, first time writer.
The problem I am having to re syncing the audio in an avi file. The file was created using Auto GK (from a DVD movie dycrypted using DVD Dycrypter).
I am in the process of converting many of my DVD into 700mb files in order to create a library inside of Window Media Center (MCE). For the most part the DVD's I rip come out fine, with no issues to speak of. However every so often (1 in 4), the newly created avi files are created with an out of sync audio track. The Audio seems to be playing to early, sometimes it is one a second, other times in it seven or more.
I have read a few posting expalining how to fix this problem. And followed the instructions given to the best of my abilty, but I am sad to say the I am unable to fix any of the rips with out of suyc audio.
Below is a rundown of what I have tried. Perhaps someone might be able to tell me where I am going wrong, or perhaps even suggest a much better for my needs.
Windows Media Classic
Play > Audio Options > Internal Filters > Audio Time Shift > (enter amount) > Apply
No noticable change to the audio sync.
Window Movie Maker.
I was able to dublicate the audio track and shift it to where I want it to be. The problem with this is a) they are in wmv format and b) they are WAY to large (around four gigs)
VirtualDub
Audio > Interleave > Adjust skew > (enter amount) > Video > Compression > Codec
also
Audio > Interleave > Adjust skew > (enter amount) > Video > Direct Stream Copy > Save
Again no noticable change to the audio sync.
VirtualDubMod
I couldnt find the option to adjust audio sync
Cuttermaran
Doesnt seem to accept avi files.
Thoughts?
In VDMod, 'Streams>Stream list'. R click on on the stream and select 'Interleaving'. It's under 'Audio skew correction'. 1 second=1000ms
What you might be running into during ripping is some video right before the main movie and that's where/when the audio begins. That will change the length of the audio and throw it out of sync when it's not included. Decrypter is probably skipping it and that could cause your problem. Or not.
That type of sync loss can be corrected by a offset. Another type of sync loss is gradual loss during playback. That's a bit harder to fix. Get a combination of both, and throw in VBR audio, like when you paste together some videos, and it really gets complex.
And welcome to our forums. -
Originally Posted by ajedale
If you decrypted properly to begin with, the chances are very good you'd never have the problem. That being said though, it's very easy to fix, assuming it's a constant asynch (off by the same amount all the way through). -
Great!
Its always the little things you end up overlooking. The 1000ms=1 sec was the problem.
Thx for all the help
YouTube Rips - Audio Quality
By kingoftomorrow in forum Video Streaming DownloadingReplies: 1Last Post: 5th Mar 2012, 17:48 -
editing H264/mp4 videos and synce issues
By Jmart285 in forum Newbie / General discussionsReplies: 1Last Post: 18th May 2011, 08:09 -
Audio issues with high quality rips..
By SE14man in forum Newbie / General discussionsReplies: 3Last Post: 20th Mar 2010, 20:28 -
Converting rips to large .avi files
By HartsVideo in forum Video Streaming DownloadingReplies: 2Last Post: 24th Jul 2009, 23:32 -
DVD to *.avi rips with *.srt subtitles
By WhiteFox in forum Video ConversionReplies: 0Last Post: 3rd Sep 2008, 11:51
