Hi to all.
I’ve got full HD new camera Canon HF S10. I know already how to edit video from that camera in Vegas 9 for the internet. But I can’t get a clue how to make/burn DVD from original AVCHD (mts & m2ts) files edited in Vegas for example, and not to loose quality (or resolution). I shoot originally at 24Mbps in Full “HD" with 1920x1080 pixels. I want to keep that quality or what was the point to buy that camera? Please advice.
You need a blu-ray player. DVD-video doesn't support HD. You can use DVD5 media, and make an AVCHD disc on DVD5 for playback on a blu-ray player, but you won't fit very much running time on it assuming you use the same bitrate (20-30 min)
You would export to h.264 blu-ray and author with DVD Architect, or even use free apps like multiavchd.
Since you are re-encoding (at least some segments when you edit in Vegas) you will lose some quality in those segments. You can minimize quality loss by using higher bitrates, but at the expense of running time with fixed capacity media
Another option is to use HTPC or a media player like Tvix, Popcorn Hour, or WD Media Player -
Thanks. I'm re-encoding in Vegas for the internet only. I prefer to do not re-encode for disc, but not many software can deal directly with mts files. Even I'm not sure if for example when Premier SC4 editing those mts files were they encoded before editing or not?Originally Posted by poisondeathray
Can you tell bit more about DVD5 please?
AVCHD on hard drive: creating new AVCHD folder structure
By Phil_W in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 1st May 2011, 14:46 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 01:06 -
AVCHD In DVD+R
By catracho2009 in forum Authoring (Blu-ray)Replies: 6Last Post: 10th Jul 2010, 16:05 -
AVCHD to DVD: how to?
By taboo in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 16th May 2010, 17:47 -
AVCHD to DVD etc.
By hperrier in forum Blu-ray RippingReplies: 4Last Post: 10th Dec 2009, 11:59
