I captured some shows the other day and I decided to do them as variable bit rate instead of constant in MMC 7.5. I got a great capture but when it came time to edit, neither of the progs i used (m2-edit pro, vcdcutter) would do them. Does anyone know why they don't like VBR as opposed to CBR? Anyone know how to edit VBR files easily (no re-encoding)? Any help is always appreciated!!!
Thanks in advance!
P.S. When i set the bit rate setting to 2.72mb/s with VBR is that the average, the low, or the high in MMC 7.5? Just curious.
Results 1 to 1 of 1
Aiwa HV-MX100 display doesn't light up & stop button doesn't work
By TurboJoe in forum Newbie / General discussionsReplies: 15Last Post: 12th Feb 2011, 18:07 -
[SOLVED] TMPGEnc DVD Author doesn't like VBR??
By Taeran in forum Authoring (DVD)Replies: 5Last Post: 19th Sep 2008, 18:11 -
PAL to NTSC..FAVSC doesn't work anymore and BeSweet Doesn't give me some op
By sandman423 in forum Video ConversionReplies: 13Last Post: 11th Mar 2008, 05:58 -
Camera video doesn't work in frame after editing
By synlupri in forum Newbie / General discussionsReplies: 2Last Post: 13th Dec 2007, 23:35 -
mpeg 4 realtime bitrates vs multipass mpeg-2 VBR
By miamicanes in forum Capturing and VCRReplies: 5Last Post: 9th Sep 2007, 21:37
