I've got a Sony TRV-19e camcorder
I've got a Technica Wireless Lapel Mic system
I want to record video and have the sound be recorded from the lapel mic
Problem: the mic system has a 6.35mm jack and the camcorder has got a 3.5mm jack
Solution: get an adapter
Problem: got adapter, but it's tooo thick!
I can get it in, but its a really tight squeeze + doesn't fully go in
I've looked around and can't find any adapters that have a thin end suitable for my needs
Can someone suggest anything?
OM
ok... i think i've found my solution
get an extension for the 3.5mm jack
i;ve looked on ebay and for the same price, i can get a 1m cable or a 5m cable
logic says: get the 5m cable!
but: would there be any harm in getting the 5m cable?
i.e. there would be a loss of sound quality because of the extra distance the data has to travel??
any replies to the above would be great
thanks
Using wireless mic with shotgun mic on Canon HF G10
By jimleben in forum AudioReplies: 5Last Post: 23rd Jan 2012, 20:11 -
LG HT 305SU (MIC IN / MIC OUT Problem)
By iamjamal in forum DVD & Blu-ray PlayersReplies: 0Last Post: 25th May 2011, 16:38 -
Mic hiss problem ???
By 3thman in forum AudioReplies: 2Last Post: 26th May 2010, 11:24 -
Audio/Video jack - is this a headphone jack?
By OM2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 26th May 2009, 16:10 -
VCR capture/Sony MiniDv jack problem
By dADDo in forum Capturing and VCRReplies: 2Last Post: 5th Dec 2007, 16:44
