Hi I have a movie that is "iso"
it is 6.5 gig long (for a 2 hr movie)
The only player that works is LAN player (Divx works but no sound)
If I can get this converted some how & just get it burned.
I tried to download those "free " players but they leave a watermark(unless you buy it)
For just one movie its not worth buying anything.
Please help
Thanks![]()
If you have a dual layer DVD disc, just burn the ISO to DVD with ImgBurn. If you only have single layer discs, try opening it in DVDShrink and 'shrink' it to a single layer size.
I'm guessing from the size it's a MPEG-2 DVD movie. If it's some form of AVI video, then it could get a bit more complicated. MediaInfo may be able to read the video inside the ISO container.
All the above is freeware and very easy to use.
And welcome to our forums.
You can also mount the ISO image as a virtual DVD drive with Daemon Tools. Then you can access the VOB files with whatever software you want.
HD TV Best Deal for 40-50 in HD TV? I have no clue about TV's
By sandman423 in forum Newbie / General discussionsReplies: 17Last Post: 14th Jan 2012, 23:33 -
To many .ISOs to deal with
By jclarkyyy in forum DVD RippingReplies: 12Last Post: 20th Jan 2010, 23:56 -
Such a deal...HV30
By zoobie in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 20th Jun 2009, 14:45 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 18:48 -
Deal or No Deal
By dairymann in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2007, 14:46
