I have encoded around 5 .avi files to mpg using TMPGenc. So far most of them are pretty good quality but some of the darker scenes have slight pixelation problems. I was just wondering what are the best settings to use when trying to convert an .avi/divx file to a video cd(ntsc). What I have been doing is loading the video(ntsc) template and then under settings changing the picture to interlaced, 4.3 NTSC. What are the best settings.
Well, if you are trying to make a standard vcd like one used to play in a standalone dvd player, you will have to use the standard VCD ntsc standard. You will want to limit the amount of transcoding you do to the file. Capture it in bets quality then transfer directly to VCD, the more times you encode it the worse off quality will be. But VCD itself is subject to these types of problems. You will occassionally see pixilization or blurring. To really boost the quality significantly you would create SVCD or XVCD,if your player supportsthem of course. A XVCD would have a higher bitrate and thus more data in each scene, unfortunately the downside of XVCD is most Standalones have some problems with them(check for yours) and the more data you use the more space it takes up.
901102 - best VCD quality
By hamidi2 in forum Video ConversionReplies: 32Last Post: 26th Aug 2018, 18:49 -
best audio video quality of youtube poor quality and not hq flv videos.
By nusratjaveid in forum Video ConversionReplies: 3Last Post: 20th Jun 2010, 19:23 -
Convert .avi movie files to vcd or dvd without loosing picture quality
By akakiami in forum Video ConversionReplies: 8Last Post: 8th May 2010, 17:01 -
Movie quality for VCD
By dilanalex in forum Newbie / General discussionsReplies: 12Last Post: 21st Apr 2009, 01:42 -
How to add Watermark to VCD MPEG1 without Quality Loss?
By shebi in forum Authoring (VCD/SVCD)Replies: 3Last Post: 15th Apr 2009, 13:13
