Results 1 to 11 of 11
  1. hi I have been using DVDShrink for many years. Now when I burn a DVD with DVD43, DVDShrink, and Nero v8. The DVD will only play in my PC and NOT on any of my DVD players. [Please check you system or unable to read Disk]
    This just started recently... I think it might be one of Microsoft's updates for IE.. I am using IE v6... This seems to be happening on all of my PCs... any help is appreciated...
    Update: The media that I am using is Verbatim Printable DVD+R Media 16x max
    System(s)
    AMD 64 3000+, Self built Windows XP Pro sp3 with sp4 updates, Ms office 2007, dvd43 v4.4.0.0, dvd shrink, Nero v8.....
    AMD 64 4600+, HP , Windows Media Center 2005, IE 6 updated also " "
    Intel 1.8Hz, Dell, Windows XP Pro " "
    New
    AMD Speron, Windows Media Edition 2005, IE v8
  2. DVdshrink doesn't actually burn the disc. It employs another program to do the burning. You could try imgburn to do the burning. Imgburn will produce more compatible burns.
    Believing yourself to be secure only takes one cracker to dispel your belief.
    Jan 2007
    Republic of Texas
    It has nothing to do with IE, but most likely the brand of blank DVD disc you are burning to. This would explain why it would only play on the unit that burned it. (You did not include info on the DVD media you are using. That would have been more helpful to us then the info about your PC.) Also, as Dv8ted2 suggested, you might want try ImgBurn, which is far superior to Nero.
  4. Banned
    Freedonia
    The ONLY consistently reliable media brands available any more are Taiyo Yuden (you will have to order these online) and Verbatim. That's it. If you use anything else, it's got a good chance of being garbage. Yes, almost certainly your discs are junk and that's why you're having problems. And we strongly recommend the use of ImgBurn, which is free, over Nero. Nero is OK for burning data discs or CD audio discs, but I wouldn't trust it for anything else like DVD movies.
  5. I updated my original post and am going to try the ImgBurn burning software... thanks
    Another question is there any good software for 64bit Windows. DVD43 does not work with it.... my new PC is 64bit vista.
  6. anydvd will work with 64bit windows.
    I can confirm this.
  8. hi all just an update to my questions. I noticed in my Widows 2005 Media edition system, if I cancel the burn to disk after dvd shrink finishes coding and shrinking. Nero [8.3.60] asks for a disk... I cancel this operation, then run nero express for DVD movies, add the files, and burn the disk. this process seems to fix the DVD players DVD ERROR UNREADABLE MEDIA.
    *note: I am am also going to try this on my XP machine to see if this works also.
  9. you ignored all the good advice you got and insist on burning with a big stinking pile of garbage. nero is only surpassed by roxio at the bottom of the list.
    verbatim or taiyo yuden burned with imgburn, there is no other high quality combination.
  10. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    FWIW Nero for burning only has never done me wrong
    Gotta agree about Roxio - when it was Adaptec it was OK IMHO
    If in doubt, Google it.
    Aug 2009
    I've been using Nero for a few years quite happily, but recently found that v9 produces rubbish.
    Imgburn sorted it out nicely.
