I am doing a backup to DVDR of my triology of LOTR.
Movie DAR is 2.35:1.
If I decide to encode this as 16:9, I will have to add black borders to it (or just keep the original ones), and encode.
I was wondering is it possible to crop the movie a little bit from 2.35:1 to 2.21: 1, and encode it without black borders, and author it with 2.21:1 flags? But I read somewhere that DVD is only compliant to 4:3 and 16:9, not 2.21:1.
Will it work with hardware DVD playback, if I encode and flag it as 2.21:1?
If not, is there a way to encode it without black borders at all?
d4t.
DVD is either 4:3 or 16:9.
That's all. Not 2.35:1, not 2.2:1, not 1:1.
If you don't want to letterbox, you have to crop the edges, and/or distort the image to fit 16:9. -
2.21 is a valid mpeg-2 aspect ratio, but not valid for DVD. As AlanHK pointed out, you have only 2 real options - crop (please don't) or add borders (which is what commercial DVDs do). Your third (and unrealistic) choice is to stretch the image to fill the frame.
Read my blog here.
So let me see if I got it right.
There is no way to encode a 2.35:1 movie without black borders, and after it is encoded, add the borders?
So what you guys are saying, is that I NEED to encode it with black borders, is that it? -
No. (Not for MPEG for DVD -- if you're making AVI or MKV or other formats for playing on a PC, you can.)Originally Posted by d4t
Yes.Originally Posted by d4t
Just look at any wide format movie on DVD and you'll see that's what they've done.
What's the problem with doing that anyway? There is very little information needed to encode a black rectangle, so it's not bloating the file.
HOWEVER if your DVD player can play AVI files, you may be able to use other ratios; depends on the player.
Black borders all around video
By techboy_66 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 30th Oct 2010, 17:01 -
Cutting black borders
By HamishT in forum Authoring (DVD)Replies: 17Last Post: 4th Mar 2009, 17:53 -
Does anybody know how to convert 16:9 to 4:3 with black borders?
By tuanvn.2007 in forum Video ConversionReplies: 7Last Post: 20th Sep 2008, 02:13 -
Black Borders won't go away!!!
By mirandapanda in forum Newbie / General discussionsReplies: 6Last Post: 10th Sep 2008, 01:49 -
how do you get rid of black borders when trying to convert file to DVD
By whodini in forum Newbie / General discussionsReplies: 1Last Post: 20th Jan 2008, 16:15
