hihyi
Was using DVDshrink all the way with no problems.. but just formated my laptop and IE now is 8.0 cant copy at all. This is the eror message .. can help me ? thanks
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Program Files\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 10/26/2004 5:35:34 PM
Nero API version: 6.6.0.18
Using interface version: 6.3.1.4
Installed in: C:\Program Files\Ahead\Nero\
Application: ahead\Nero - Burning Rom
Internal Version: 6, 6, 0, 18e
Recorder: <MATSHITA DVD-RAM UJ-850S>Version: 1.20 - HA 0 TA 1 - 6.6.0.18
Adapter driver: <atapi> HA 0
Drive buffer : 2048kB
Bus Type : via Inquiry data (1) -> ATAPI, detected: ATAPI
Connected to MMC as unknown drive with class-nr : 1
Drive is autodetected - recorder class: Std. MMC recorder
=== Scsi-Device-Map ===
DiskPeripheral : Hitachi HTS541612J9AT00 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : MATSHITA DVD-RAM UJ-850S atapi Port 0 ID 1 DMA: On
=== CDRom-Device-Map ===
MATSHITA DVD-RAM UJ-850S E: CDRom0
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1014MB (1038440kB)
Free physical memory: 327MB (334880kB)
Memory in use : 67 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
1.6.2009
NeroAPI
12:09:17 PM #1 Phase 112 File APIProgress.cpp, Line 276
DVD-Video files reallocation started
12:09:17 PM #2 Phase 114 File APIProgress.cpp, Line 276
DVD-Video files reallocation completed (no file modified)
12:09:17 PM #3 Phase 111 File APIProgress.cpp, Line 276
DVD-Video files sorted
12:09:18 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
12:09:18 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 842
DRM: StartDrmRecording(RealRec:1, ImageRec:0, Copies:1)
DRM: Beginning burn process.
12:09:18 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
12:09:18 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3309
12:09:18 PM #8 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
12:11:46 PM #9 Text 0 File DVDR.cpp, Line 2571
Recording mode: unknown Recording Mode
12:11:46 PM #10 Text 0 File Mmc.cpp, Line 21774
Set BUFE: Buffer underrun protection -> ON
12:11:47 PM #11 Text 0 File DVDR.cpp, Line 2726
Start write address at LBA 0
DVD high compatibility mode: Yes
12:11:47 PM #12 Text 0 File Cdrdrv.cpp, Line 8892
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+RW (9), Part Version: 1.1x (2)
Disc Size: 120 mm, Maximum Rate: 10.08 Mbps (2 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: re-writable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 24A31F h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Disc Application Code: 0 / 0 h
Extended Information indicators: 1 h
Disc Manufacturer ID: MKM.....
Media type ID: A02
Product revision number: 0
Number of Physical format information bytes in use in ADIP up to byte 63: 57
Media Specific [16..63]:
00 00 01 4D 4B 4D 00 00 - 00 00 00 41 30 32 00 39 ...MKM.....A02.9
23 00 94 79 64 02 20 00 - 9C 7A 6C 02 20 00 9A 7B #..yd....zl....{
68 02 20 12 12 10 E0 00 - F0 00 00 00 00 00 00 00 h...............
12:11:47 PM #13 Text 0 File DVDR.cpp, Line 2969
EndDAO: Last written address was 511
12:12:05 PM #14 SCSI -1128 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0C7E4A00
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x11
Sense Qual: 0x00
CDB Data: 0x51 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF1 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x11 0x00
12:12:05 PM #15 Text 0 File DlgWaitCD.cpp, Line 270
Disc check failed: Medium not writable (Wrong CD)
12:12:05 PM #16 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO
12:12:05 PM #17 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: MATSHITA DVD-RAM UJ-850S, Media type: DVD+RW
Disc Manufacturer ID: MKM, Media Type ID: A02, Product revision number: 0
Disc Application Code: 0, Extended Information Indicators: 1
12:12:05 PM #18 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
Insert empty disc to write to.
(Medium in drive: unknown. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD-RAM, DVD-R DL, DVD+R DL.)
This disc is not empty.
(Medium in drive: DVD+RW. Medium required by compilation: DVD+R/RW, DVD-R/RW, DVD-RAM, DVD-R DL, DVD+R DL.)
12:12:05 PM #19 Text 0 File AudioCompilationImpl.cpp, Line 867
DRM: DRM burn session terminated.
12:12:05 PM #20 Text 0 File AudioCompilationImpl.cpp, Line 896
DRM: Closing entire DRM handling. Bye.
Existing drivers:
File 'Drivers\ADPU160M.SYS': Ver=v3.60a (Lab01_N(johnstra).010529-2218), size=101888 bytes, created 8/10/2004 8:00:00 PM
File 'Drivers\PXHELP20.SYS': Ver=2.03.26a, size=20576 bytes, created 5/12/2005 6:54:10 PM (Prassi/Veritas driver for win 2K)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 20 of 20
Apparently, DVD Shrink doesn't coexist all that well with IE8 at the moment, from reports we've heard here and elsewhere. The only option appears to be to remove IE8 and go back to IE7, or earlier.
(You might also want to remove the line that begins with '1A20-' from the beginning of your error log - I believe it's a product key/serial, and shouldn't be displayed on a public forum.)If cameras add ten pounds, why would people want to eat them? -
oh this is wat I suspect too.. thanks .. shall re format again .. so sad.. thanks alot !
Now i reformat again .. still have the error message . But sometimes can extract and copy too.. now dun know wat is wrong ??? sigh
Can u teach me how to switch to imgburn and where to get the software ? Thanks so much !!
Windows XP 5.1
IA32
WinAspi: -
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Free physical memory: 440MB (451408kB)
Memory in use : 56 %
Use Inquiry : 1
2.6.2009
NeroAPI
5:34:09 PM #1 Phase 112 File APIProgress.cpp, Line 276
5:34:09 PM #2 Phase 114 File APIProgress.cpp, Line 276
5:34:09 PM #3 Phase 111 File APIProgress.cpp, Line 276
5:34:10 PM #4 Text 0 File Reader.cpp, Line 127
Reader running
5:34:10 PM #5 Text 0 File AudioCompilationImpl.cpp, Line 842
5:34:11 PM #6 ISO9660GEN -11 File geniso.cpp, Line 3309
5:34:11 PM #7 ISO9660GEN -11 File geniso.cpp, Line 3309
5:34:11 PM #8 Text 0 File Burncd.cpp, Line 3233
5:35:24 PM #9 Text 0 File DVDR.cpp, Line 2571
5:35:24 PM #10 Text 0 File Mmc.cpp, Line 21774
5:35:24 PM #11 Text 0 File DVDR.cpp, Line 2726
5:35:24 PM #12 Text 0 File Cdrdrv.cpp, Line 8892
End Physical Sector Number of Data Area: 25E69F h
Media type ID: A02
5:35:24 PM #13 Text 0 File DVDR.cpp, Line 2969
5:35:44 PM #14 SCSI -1128 File Cdrdrv.cpp, Line 1182
SCSI Exec, HA 0, TA 1, LUN 0, buffer 0x0AFC4C00
Sense Code: 0x11
Sense Qual: 0x00
5:35:44 PM #15 Text 0 File DlgWaitCD.cpp, Line 270
5:35:44 PM #16 Text 0 File DlgWaitCD.cpp, Line 282
5:35:44 PM #17 Text 0 File DlgWaitCD.cpp, Line 2483
5:35:44 PM #18 Text 0 File DlgWaitCD.cpp, Line 448
5:35:44 PM #19 Text 0 File AudioCompilationImpl.cpp, Line 867
5:35:44 PM #20 Text 0 File AudioCompilationImpl.cpp, Line 896
Existing drivers:
Registry Keys:
Originally Posted by guns1inger -
What kind of media (CD-R/W? DVD-R/+R/-RW?) do you have in the drive? Nero's indicating the disc isn't what it's looking for (not enough space/the right type of disc).
I'd recommend Imgburn over Nero, too (the forum should automatically turn the word 'Imgburn' to the left into a link to VideoHelp's Tools page for the software, where you can download it or follow the links to Imgburn's homepage). Be aware, though, that it's mostly for straightforward burning. You won't be able to do all the things Nero can do (good or bad), like feed it video files and have it create a Video-DVD disc for you.If cameras add ten pounds, why would people want to eat them? -
Look at your first post. See how DVD Shrink is a different colour. Click on that and it will link to the DVD Shrink page in out Tools section. There you will find a link to the Imgburn version.
Install Imgburn, then Shrink and it should all just work.
FWIW, I never Shrink and burn. I always test play first to make sure that everything still works, and that the quality is good enough. Then I burn.Read my blog here.
Me having DVD RW . It has the same space as the source disc. Coz the source disc is created by me using tmpgenc author.
Actuall normally I only use nero to copy files into DVD disc and store as backup and the second use is for DVD shrink and then will auto use nero to burn into the DVD-R or DVD rw
Originally Posted by Ai Haibara -
ok i get the link and will read first .
Must uninstall DVD shrink and imgburn again . then install first imgburn and then DVD shrink ?
Must I uninstall nero before all the above ? I use nero to copy files to dvd disc as storage only and the other use is with DVD shrink
Thanks for all helpers here !!
I would uninstall Shrink, but Imgburn is fine.
Personally I would uninstall Nero just to get back all the disk space it uses. You can use Imgburn to copy pretty much anything. I use it for everything but audio, which I use Prassi ONES for.Read my blog here.
Are you sure the DVD-RW disc you're using is blank/empty? There's something Nero doesn't like about the destination disc, as the errors indicate, and Nero's refusing to write to the disc as a result. I should probably also note that RW discs do degrade over time and with multiple uses.Originally Posted by yueyun44
Also, are you sure you've told Nero to write to a data disc, and not a Video (VCD, SVCD, DVD-Video, etc.) disc?
I'd prefer to figure out what Nero doesn't like about the destination disc(s) you're using, because Imgburn might also have a problem with them. Maybe.
RWs are not the most reliable discs to work with. I have a handful that I use regularly to move video from my DVD recorder to the PC and for testing purposes. Every so often, for no good reason, one will refuse to be recognised in the PC, or by the DVD recorder. In those cases I find that I have to erase the disc in the other device to get it working again.
And they don't last forever. The cheap ones tend to die pretty quickly, the better ones might lst quite a while, but they have a finite number of burns in them.Read my blog here.
I have download the DVDshrink with imgburn file (that is one file with DVD shrink n imgburn together rt ? ) from the DVD shrink link.. works better but I think u guys were rt abt the DVD RW too .. I use another batch ones no issues.. probably the usage is up as I hv using them for 2 yrs already.
So shall I change to IE 8 now or leave it alone as IE 6 ??
Thanks so much for all replies!! Appreciate all from my heart ! -
Get IE8 as soon as you can,Originally Posted by yueyun44Believing yourself to be secure only takes one cracker to dispel your belief.
but just worried whether IE 8 will affect dvd shrink again ? Why as soon as I can ???
IE8 and dvdshrink have nothing to do with each other. They are unrelated and coexist nicely. I have IE8 and dvdshrink on my computer with no problems. IE6 is a security nightmare that should have been dead and buried long ago.
Believing yourself to be secure only takes one cracker to dispel your belief. -
Ai Haibara's previous post suggests that some people are indeed having problems with IE8 and DVD Shrink, so rather than just essentially saying "It works for me, therefore no one else could possibly be having problems", I'd feel a lot better concluding only that it works OK for you.Originally Posted by Dv8ted2
EVERYTHING that Microsoft writes is "a security nightmare that should have been dead and buried long ago." EVERYTHING. Implying that IE8 is "better" from a security perspective to me seems a little like saying it's oh so much better to be shot in the head and die instantly than to have your throat slit and bleed to death. From my perspective you're dead either way. It's kind of hard to aruge that one is "better". Similarly if it doesn't already, it will just be a short matter of time before truly horrific security flaws get found in IE8 that take forever to get fixed, if they even get fixed at all. People who care anything about security DON'T EVER UNDER ANY CIRCUMSTANCES use IE.Originally Posted by Dv8ted2 -
Agreed, but if IE 8 and shrink work on Vista, without issues on multiple computers, then something else is wrong.Originally Posted by jman98
The problem that Ai Haibara is referring to reared it's head with the beta of IE8, but the full gold IE8 fixed the problem, so I reiterate that IE8 and shrink have nothing to do with each other and coexist nicely.
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 26Last Post: 19th Sep 2013, 22:03 -
CloneDvd2, Dvd Decrypter, Dvd Fab, Dvd Shrink? Help Choosing Software...
By frieday in forum DVD RippingReplies: 10Last Post: 5th Aug 2009, 08:14 -
What to do when DVD shrink does not shrink enough
By Firewire60 in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 23:07 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59 -
DVD wont shrink enough using DVD shrink?
By fazeshot in forum Newbie / General discussionsReplies: 4Last Post: 6th Aug 2007, 21:31
