Hi,
I used to have a DV cameria on a IEEE port and whatever i filmed, i could capture using Pinnacle Studio and in the "Capture option" i could select to output in "PAL or NTSC". (I have fiamly in N.America and i would send them NTSC DVDs of the kids etc.). Life was simle. Then the DV broke down and i gout a Canon HF20 Flash camcorder. The annoyance is "Pinnacle Studio" does not recognize the device as its USB connected to the PC.
I can copy the clips to the HDD and open them in Pinnacle Stusio 11.1 and burn a DVD. But it's PAL...
So, now i'm trying out different software, and i capture clips (but they're PAL). How do i convert them to NTSC? So that i can burn a DVD and send across the oceanAre there any straight forward softwares which recgnizes projects or *.mpg files after a project is rendered and converts them.
Thanks very much for your responses.
	Easiest, use for example convertxtodvd, choose ntsc in the settings, add the dv and convert.
 Or better methods, https://forum.videohelp.com/topic368261.html
  NTSC video with a film-like/PAL to NTSC conversion type of look that shouldn'tBy Bix in forum RestorationReplies: 34Last Post: 8th Feb 2010, 16:17
  PAL to NTSC, NTSC to PAL framerate conversion?By Baldrick in forum Video ConversionReplies: 44Last Post: 6th Dec 2009, 00:31
  PAL DVD to NTSC Conversion (read as much as I could)By DW in forum Video ConversionReplies: 3Last Post: 27th May 2008, 03:42
  NTSC to PAL, PAL to NTSC framerate conversion?By Baldrick in forum Video ConversionReplies: 23Last Post: 23rd Apr 2008, 12:19
  PAL to NTSC DVD Conversion ProblemBy squallx404 in forum Newbie / General discussionsReplies: 4Last Post: 8th Oct 2007, 06:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
