Hi, I recently forayed into HD video with a Canon HF20. I've installed Vegas 9.0 Platinum & Architech Studio 4.5. I am trying out a test project to understand the software. Here's what I've done
- shopt a couple of clips (*.mts)and downloaded them to my HDD
- Started a new project in Vegas 9.0 and inserted the clips into the timeline.
- Slect "Make Movie" and the option to burn it to a DVD. It goes about its rendering and generates a .mpg file. At the end it asks me "Click the Send to DVD Architect Studio" button to launch DVD Architect Studio with you rendered Movie". I do that
- It starts up DVD Architech Studio and immediately gives me an error box "
Warning: An error occured while opening one or more files
The file is an unsupported format
- In the details, it shows me the path of the *.mpg file.
I sincerely appreciate your help and answers. It's quite frustrating.
i've never used studio but i do use vegas pro, maybe the instructions will work. try rendering to dvd spec .mpv and .ac3 separately and then importing into architect.
after you finish your timeline, click file\render as. choose mainconcept mpeg-2 and from the dropdown arrow choose a template that matches what you want to render to. i.e - dvd architect pal mpeg-2 or ntsc and set it to video only(.mpv). then render as again to get the audio stream, ac3 if it's listed.
sorry if this doesn't apply to studio.
Does Sony Vegas Movie Studio HD Platinum 10 do 60fps?
By vid83 in forum EditingReplies: 13Last Post: 7th Feb 2011, 19:33 -
preview mode in the timeline Using Sony Vegas Studio Platinum 10
By JackDalton in forum EditingReplies: 5Last Post: 26th Oct 2010, 04:16 -
How to edit overmodulated audio in sony vegas movie studio platinum 9
By floriday_girl in forum EditingReplies: 1Last Post: 13th Sep 2010, 09:59 -
Sony Vegas Studio 8 Platinum Wipes
By luigi2000 in forum EditingReplies: 2Last Post: 30th Aug 2008, 15:46 -
SONY Vegas Movie Studio Platinum 8.0
By pcanaveral in forum EditingReplies: 4Last Post: 13th Oct 2007, 23:38
