I read that Handbrake can be used to convert mkv to regular avi that a standalone will play. However, when I try to install Handbrake, I get the following error message. Is there any way to solve this problem (except installing more memory)? If I cannot use Handbrake, what other simple alternative should I try? Is AlltoAVI a good choice?
While waiting for a reply to this post, I tried AlltoAVI, but the result, according to G-spot, still had the x264 codec in the video. So I tried Avidemux and chose the first selection, <MPEG-4 ASP(XVID)> and that worked. The G-spot didn't show any x264 codec, and the resulting AVI played fine in my DVD player.
Check this link: http://trac.handbrake.fr/wiki/SupportFAQ#mem
Quote: "When I try to launch the GUI it says "Your system does not meet the minimum requirements for HandBrake...."¶
Either your screen resolution is too low or you simply do not have enough RAM.
Screen resolution must be above 1024x720 and you must have at least 256MB ram available to the operating system.
Please note, we do not intend to support netbooks."
Mac - Handbrake: all x264 filters off? - MKV
By heinza in forum Newbie / General discussionsReplies: 1Last Post: 12th Nov 2011, 19:26 -
Help Converting 1080p x264 (.mkv)
By lil_chris_chris in forum Video ConversionReplies: 6Last Post: 10th Nov 2009, 08:49 -
By lil_chris_chris in forum Newbie / General discussionsReplies: 1Last Post: 7th Nov 2009, 15:19 -
Question about quality when converting from mkv to avi
By CasualObserver in forum Video ConversionReplies: 2Last Post: 17th Feb 2009, 18:38 -
Converting or demuxing MKV's to another container using x264 or vc-1
By dm_0001 in forum Newbie / General discussionsReplies: 6Last Post: 9th Jan 2008, 14:19
