Has something changed at YouTube?
My old faithful method of editing and encoding short (under 5 minute)
video clips with AviDemux(xvid, two-pass by file size, mp3 audio, downsized
to about 75% of full DVD video) has gone
completely south. Every video I put up (35 - 45MB average) is unwatchable due to
big blocks and skipping.
I uninstalled and reinstalled/upgraded AviDemux - no help.
I have purchased Mainconcept Reference and am now uploading
vids with the Apple Ipod Mobile(640x480) codec and all is well(try it...it's
very nice for YouTube stuff IMO).....but I'd love to know why my old faithful
AviDemux is failing me.
Could it be dueling codecs or something? Too many programs with
that came with the same Xvid/Divx pre-installed?
I'm pretty codec stupid actually.
Results 1 to 9 of 9
avidemux doesn't rely on system installed codecs, so even if you screw around with your xvid/divx settings/install it shouldn't affect avidemux
Does the xvid video look/play normally locally on your pc before uploading to youtube?
Did it happen more than once? Maybe it's an isolated case or screw up on Youtube's end?
You could use avidemux to encode h.264 as well (instead of xvid) -
Seriously doubt it. This probably won't make a difference, but you can use the avidemux portable version (not installed) and it runs in it's own environment, own folder etc...Could Mainconcept Reference have messed up AviDemux?
When you have time to learn, there are a few illustrated guides etc.. for vdub and avidemux encoding.
Cheers -
xvid is h263. h264 is just a newer, more advanced codec. youtube has preferred uploads in h264 for awhile. the size limit is also 1GB now, so higher quality HD vids can be uploaded.
I really don't have a "problem" encoding with AviDemux. I don't get fancy with my encodesOriginally Posted by poisondeathray
but a little 5 minute video encoded to Xvid is simple for me....because of the built-in tools. I'd
like to stick with it because it is obviously a better editor than Mainconcept Reference. An extra step
of outputting as MPEG-PS from AviDemux....then encoding/transcoding with Mainconcept Reference
won't kill me....or my two big HDD's....it's just the principle of it...
yes. (a)vanced (v)ideo (c)odec - avc - h264 - and x264 are the same thing. x264 is the open source version.
Gotcha...I'll try one today.Originally Posted by minidv2dvd
Thank You
avidemux question ....
By zero7404 in forum Video ConversionReplies: 6Last Post: 25th Mar 2012, 10:01 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 21:07 -
AVIDemux question
By imhotepiii in forum EditingReplies: 8Last Post: 16th May 2011, 17:07 -
Avidemux question...
By Immortal25 in forum Video ConversionReplies: 13Last Post: 15th Oct 2010, 10:18 -
Newbie with a question on using Avidemux
By The Monarch in forum Newbie / General discussionsReplies: 6Last Post: 28th Sep 2009, 23:25
