So here's what's going on. Windows Media Stream Editor only lets me mux multiple audio tracks that are coded different languages. So I can't use 2 English tracks, one being a commentary file.
One thing I've tried is converted it in Windows Media Encoder with a different language code- I just designated it as Zulu in the settings. But I can only get that to convert as high as 128kbps. (If I use the original settings (384kbps) it will give me a vague codec error about "0XC00D0BC2")
And since the bitrates have to be the same to be muxed properly, I run this 128 kbps file thru dPoweramp music converter. I get a 384kbps file now no problem- EXCEPT the new .wma file I've coded is no longer coded Zulu, but back to English! So I'm back to the same problem with Stream Editor. Any ideas? Thanks guys
Kevin
Results 1 to 9 of 9
its for my xbox 360. I use an hfs external drive for wmv hd movies
I figured out a way to put 2 tracks into a wmv-hd file, but when playing thru my xbox360, only 1 track shows up. All the answers I've found online show that it won't support more than 1 track. Not yet. Damn
detail what you have done please...wmv-hd with 2 audio (5.1 channels) is playing on my xbox360 (PAL) with no problem...
_ -
well. I got the original codec error in Media Encoder when I tried to upsample the commentary track to encode to 384 kbps 5.1. Then I tried, to encode it as a video, even tho there is no video, and it let me encode to 384 5.1, then I demuxed the audio out Stream Editor. And with a new language code. The two tracks now show up in WMP and play fine on my computer. But when I copied the new wmv over to my external hard drive and played them on the xbox 360. Only 1 audio track.
success. Can't believe it was only a labeling conflict. My problem was I designated my commentary track as "English-Jamaican." Not "Zulu" like I said in my first post. Since the regular audio track was "English-US" it must have confused the xbox. ('There can't be TWO english tracks!')
I went back and reencoded it, labeling it the "Zulu" language. No more conflicts, thanks b66pak, if not for your post I probly would've never revisted this
BULK remove non-English tracks from MKV container?
By soulhunter123 in forum AudioReplies: 44Last Post: 28th Dec 2018, 13:30 -
Quickest way to demux & mux audio tracks to MP4 containers?
By spycam in forum Video ConversionReplies: 3Last Post: 3rd Sep 2011, 02:32 -
MPEG Editor like Womble but with 2 video tracks?
By greymalkin in forum EditingReplies: 26Last Post: 19th Jan 2010, 07:52 -
TMPGEnc MPEG Editor 3 Trial (English version) available!
By gyoshi in forum Latest Video NewsReplies: 2Last Post: 6th May 2008, 10:25 -
Need software to mux ATSC with a data stream
By jhnlmn in forum DVB / IPTVReplies: 2Last Post: 15th Oct 2007, 11:52
