    Dec 2002
    michigan
    can i set region code through a usb external writer? all i find on searching online is to put drive in computer and play comm dvd through a player like powerdvd.
    set region code? make the dvd writer region free?
    You can just use dvd43 or anydvd and you don't have to worry about region codes.
    Dec 2002
    michigan
    I hope i can explain better, i have a standalone dvd recorder ilo r04 that i replaced the drive on. i would like to play a store brougt dvd on recorder, but it won,t play because the region was never set, as aposhed to an internal dvd writer? i would like to know if i put the drive in a external case, would it play through usb port, and be reconized by a player on the computer,
    to be set to play a region 1 dvd?
