I'm going to a country that friends have some old sony tapes recorded on sony recorder in PAL. I can't take too many stuff with me a laptop and I like to buy a camcorder with feed thru so I can capture those old tapes as well. Memory card might be better because of the compact size and maybe safer going thru magnetic fields or heat etc.
My question is do these newer ones have feed through? The other thing is since the tape is PAL if I connect it to a camcorder that is NTSC from US would that work can I capture it ? I have to change it to US NTSC standard here later.
	Almost never works.Originally Posted by INFRATOM
 I take a laptop with IEEE-1394 + Canopus ADVC-100 to do this. I either encode to PAL MPeg2 or keep PAL DV format on a portable hard drive. No need to convert to NTSC. I can play PAL at home.Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	I went to Amazon to get one, they have Canopus 110 is that same?
 http://www.amazon.com/Canopus-77010150100-ADVC110-Converter/dp/B00030ATTO/ref=sr_1_1/1...3575205&sr=8-1
	Yes that is the current model. You can easily resell it on ebay.
 Best get the optional power supply. A laptop may not be able to power it over IEEE-1394 (6pin).
 Remember DV format records about 13GB per hour so you may need a second disk drive.Recommends: Kiva.org - Loans that change lives.
	That supply there is overpriced.
 You need 5vdc at 2.5 amps.Recommends: Kiva.org - Loans that change lives.
  PAL & NTSC in the same camcorderBy griffmedia in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 24th Feb 2009, 12:55
  playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?By interlooper in forum Capturing and VCRReplies: 2Last Post: 17th Jan 2009, 15:36
  ntsc tapes pass through pal camcorder into mac for ntsc playing?By tozier9 in forum Newbie / General discussionsReplies: 5Last Post: 7th Dec 2008, 18:19
  How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45
  Pal and NTSC CamcorderBy NightFire in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 20th May 2007, 21:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
