Hey guys
I have a problem while trying to convert the rush hour 2 divx to mpeg using tmpgenc. It freezes every time at 65%. I tried usoing virtauyal dub for the sound first but i still have the same problem. Any suggestions for solutions.
thanks
Wrestling Fan For LIfe
try a program called divfix, it will rebuild the divx files index.
1st stip it then 2nd, rebuild it. This could be the problem.
Also, what methods are you using to encode? -
Your TMGEnc settings... vcd, svcd, framrate, bitrate, resolution, audio bitrate
VCD
23.976
1150 (bitrate)
resolution 350 x 240
audio bitrate 224
btw, thanks for trying to help meWrestling Fan For LIfe -
well, if you are putting it on 2 CDs, i am sure you can pump up the video bitrate sum. Find out where you are going to split it and us CDFIT for the best possible bitrate. As for the freezing, i imagine the divx is encoded at 128kbps mpeg 3 audio so encode the VCD at that. Did you strip the index and rebuild it?
Not working for me...
By Carita in forum ffmpegX general discussionReplies: 10Last Post: 20th Apr 2011, 00:02 -
Computer Guys Braggin' Time: What have you built that AIN'T a computer?
By ahhaa in forum Off topicReplies: 22Last Post: 8th Feb 2010, 15:19 -
ATi TV Wonder VE not working...
By kkpatel87 in forum Capturing and VCRReplies: 0Last Post: 1st Aug 2009, 23:27 -
AC3 on m4v not working, 48KHz AAC not working, 44.1KHz does?!?!
By dmjerbear in forum AudioReplies: 14Last Post: 11th May 2008, 18:23 -
DV not working
By mainegate in forum ffmpegX general discussionReplies: 9Last Post: 23rd Aug 2007, 19:04
