My quest. Import raw video, edit in Final Cut Express (older version) export in quicktime format, save and use (???) to convert mov files to flv (flash video) for posting to my website. If I upgrade to quicktime pro, with perian, can I export to flv? Thanks for any info. I know I can youtube it and import, but really trying to convert locally, add watermark in fFCE or the converter software, and load thru backend to my site to play with flv player (Joomla module).
only Adobe Flash allows you to export as flash (from QuickTime)
- in FCE, Add your watermark
- export from FCE to something not too compressed (like h264 with a very high bitrate and some short "keyframes")
- give it to Vimeo (better quality than youtubve and daily)
- take the resulting flv from vimeo, integrate it in your site
byeFor DVD, iPad, HD, connected TV, … iMovie & FCPX? MovieConverter-Studio 3 (01/24/2015) - Handle your camcorder's videos? even in 60p or 60i? do a slow-motion? MovieCam.
Can QuickTime Pro Convert XDCAM MP4 to .mov?
By boriega in forum Video ConversionReplies: 2Last Post: 15th Sep 2010, 16:17 -
Best .mts to Quicktime .mov converter?
By nojiri in forum Video ConversionReplies: 3Last Post: 28th Jun 2010, 19:54 -
Need Converter like Quicktime Pro
By seskanda in forum Video ConversionReplies: 9Last Post: 31st Jan 2010, 22:34 -
No sound in MOV och MP4 when I use quicktime pro
By Cazz in forum Video ConversionReplies: 2Last Post: 3rd Sep 2008, 16:02 -
YouTube (.flv) to QuickTime (.mov) on Mac OS X 10.4 doesn't work
By sailmariner in forum MacReplies: 4Last Post: 3rd Jul 2007, 08:09
